H96 MAX+ 4/32 or 4/64GB ROM TV Box Android 8
Hi Folks i?m the new one here and i came along with my first "Problem" and i hope you Guys can help me out. So I bought an H96 Max+ Android 8.1 32Gb Version with an Portable Touchpad 2.4GHz Mini Wireless Keyboard Mouse Combo Remote. And here is the Problem. First install was no Problem, the Remote worked perfect. But after a reboot, the Remote would not connect to the Usb Dongle anymore. Nothing happend, i can?t control the Box with the wifi Remote. I try to restart the Box a few times, but it won?t work. When i plug in the Usb Dongle to my Pc it all work perfect. Is there any Trick? I really need your Help. Greets from Germany
Originally posted by caliban_freak View PostHi Folks i?m the new one here and i came along with my first "Problem" and i hope you Guys can help me out. So I bought an H96 Max+ Android 8.1 32Gb Version with an Portable Touchpad 2.4GHz Mini Wireless Keyboard Mouse Combo Remote. And here is the Problem. First install was no Problem, the Remote worked perfect. But after a reboot, the Remote would not connect to the Usb Dongle anymore. Nothing happend, i can?t control the Box with the wifi Remote. I try to restart the Box a few times, but it won?t work. When i plug in the Usb Dongle to my Pc it all work perfect. Is there any Trick? I really need your Help. Greets from Germany
the mx9 pro is your friend and its cheap. If you get that box i can also help you better but everything should work right out of the box.
I have H96 max plus android 8/64gb but was sold to me with android 9 installed its a great box but can only connect to internet via ethernet (the wireless feature seems to be corrupt)
The seller sent me a copy of latest rom (RK3328_DC_H96_MAX+_noaddon_HS2734C_9_20190327.000 3) but still not connect wirelessly.
Anyone got a later version cos I am sure its just a minor issue needs attention
Originally posted by Gante View PostAndroid 9 firmware for H96 max + /4/64/
Attention! You must use attached Facory Tool 1.64 !!!
https://drive.google.com/drive/folde...V94e65sk6ZxdRO
Just use 1.64 installer and for some reason it did not work first time of trying... saw on another forum for MX8 box that sometimes need 2 attempts
Thanks heaps Gante
Originally posted by Gante View PostCan you please upload somewhere the firmware RK3328_DC_H96_MAX + _noaddon_HS2734C_9_20190327.000 3? I try. Thanks.
There are currently 2623 users online. 3 members and 2620 guests.
