H96 MAX+ 4/32 or 4/64GB ROM TV Box Android 8
Guest
Ewojtas In the factory tool at the top, there is the upgrade button and the restore button, i used the restore button and it did everything and worked.I dont know why it worked this way but it did.Now every-time i flash a box i do a factory restore first then flash it and works good, maybe that is why i had to choose the restore button this time...lol
As far as new features I havent seen any that stands out for me yet...the day dream screen is new lol...android 9 seem to be stable
And also i had to right click on both factory tool and the drivers assistant tool for them to both work this time to...good luck
I have 4/32GB version, without BT.., and obvious Gantes posted Android 9 FW is for 64GB version with BT., and every restart BT show error - constant crushing, and it is not a big deal but is there any way to remove this error to pop-up....
mo123
You are the king of obvious conclusions.., I asked for workaround because I cannot find Android 9 FW for 4/32GB - and looks like nobody has..., so Yes I know that I need FW for my version without BT...
This error is only on first boot (and every rebooot/restart), after that all good until the next restart...
BT is in default set to on. Therefore, after every restart it tries to connect.
Go to setup and turn it off. BT doesn't work in version 4/32.
Otherwise it's easy to go back to android 8.1.
And telling someone who wants to help you that he is the king of obvious conclusions it doesn't seem to me decent.
There are currently 1730 users online. 1 members and 1729 guests.
