H96 MAX+ 4/32 or 4/64GB ROM TV Box Android 8
The seller sent me this firmware https://drive.google.com/drive/folde...V94e65sk6ZxdRO, i install and wifi dont turn on.
OK Hallo to everyone in here
This is my situation:
I bought this H96 Max+ 4/32 in 15th Jan 2019 (this was the 2nd device from the same seller- the 1rst bought in 5 Jan 2019)
It says Max+ but in title says max...
Anyway everything was going ok until I tried Netflix. The control didn't move up-down-right-left (only in netflix).
I contact with the supplier and he send me this link which I found in here many times to flash the upgrade.
I tried these with any possibility but sudenly the wifi was going off in 2-3 seconds.
As I can see the firmware he send me is for H96 Max+ .
I'm going to see if I find the H96 Max firmware.
I will return for the result.
Ok News !!!
I managed to flash this file RK3328-H96MAX+_hs2734_8.1.0_20180820.1437 I found from mega link somewhere in the above posts with FactoryTool_v1.6
It worked (Netflix and wi-fi) but now I have no bluetooth !!!
Jesus!!!
Could it be possible that the firmware is wrong?
I have already send message to the seller and waiting for reply.
Gante No the 4/32 version has Bt. As speaking before the upgrade they told me to do It had the Bt even in the top of the taskbar.
dadoremix The 2nd device I bought and has the problems after the firmware upgrade worked with the RK3328-H96MAX+_hs2734_8.1.0_20180820.1437 (20 Aug 2018)
The 1rst device has the 8 Nov 2018 firmware I'm going to try this RK3328_DC_H96_MAX+_HS2734_8.1.0_20181108.2206.7z
There are currently 2542 users online. 1 members and 2541 guests.
