By the way, the KIT did not have MVR9 USB A-A cable for flashing. For me it is not critical (I have different cables), but for potential buyers this information can be useful, that they knew in advance that the package may not contain such a cable.
Linux for TV box RK3328.
Hi Robert. I know you have a lot of different TV boxes RK33xx. Can you do a simple check for me ? Download image (for example Ubuntu_Xenial_desktop), unzip, write to Sd card. To perform the initial startup and configuration Armbian on MVR9 (or any TV box). And then check the option to automatically start Armbian on different models RK33xx (just connecting the SD card with Armbian in the TV box and turn the power) ? I am interested in what models of TV boxes have the function of automatic start of the system from external media. Most likely, the system will be able to run on some models of TV boxes (I'm interested in a list of these models).
Any particular Version ? Ok found your link
And preferred method of writing to card has been a while or still the same.?
The new version of images 20180831 with support for the standard use of dtb (with manual copying of the desired option to the root of the FAT partition with the name " dtb.img"). If you are using automatic dtb mode, your system is not fully functional (some hardware is not working) or the system does not start at all. You can try to manually add your own version of the dtb file (copy from the directory "/dtb" or use files from other systems Libreelec, Armbian, etc.). To do this, copy the desired option to the root of the FAT partition and rename it to "dtb.img" (in the same way as is done in the images Armbian\Libreelec for Amlogic).
Tnx for test
The video should run smoothly (unless you resize the window). When the system is first started, background applications are actively running. This can affect video and other applications. I watched the ridiculous stuttering and slowing down\speeding up videos in the first runs of the system. If the system is given 10-15 minutes to adapt, the video should work smoothly. By the way, it is possible to work the sound should be in the GUI audio settings to choose the right device, there can be multiple devices. When i'm connect the USB sound card I have everything is determined by the machine and immediately begins to work.
Installed on my Scishion A1 ONE using the "px30-evb-ddr3-lvds-v10" dtb. It boots and comes to the login screen. I type "admin" for user and "1234" for password, but, keep saying wrong password. It does not show up using putty, either.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Trebor, that is a DTB file that is included with the Linux port by Balbes150, when you create the bootable Linux OS onto a microSD card.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 4203 users online. 1 members and 4202 guests.
