If the eMMC has a u-boot version that supports direct USB startup, it is sufficient to configure the file (extlinux.conf) and the system can run on RK. If the eMMC does not support USB startup, you can use the combined method. Write to SD card micro image u-boot for the desired model of the RK chip. Write an Armbian image to a USB drive, configure (extlinux.conf), connect both media to the device and turn on the power. The system will automatically start from the USB drive.
The images themselves are in directories with a new label (current version 19.11.3) at this link.
U-boot micro-images available for use.
