Pipo M7 Pro RileyROM 1.6
Originally posted by rrileypm View PostThis must be a tweak Pipo put into twake lock l...maybe a solution to 3g turning off when in sleep mode.
I have tried turning 3g off but still get the same kernel wakelock problem, it isn't helping battery life so I might go back to a previous version.
Miles
Do you really use the 3G?
If not, I would try the wifi version and see if that solves your problem.
Also, you might try flashing this ROM with the kernel from 1.6.
Just a thought.Randy
Originally posted by flash70 View Posthow can i browse the menu of CWM, without keys + and -??
Thank you
Giovanni from Italy
RandyRandy
I am now running the wifi version of 1.6 and can confirm that I no longer get the kernel wake lock problem.
Seems a strange solution to the 3g problem?
I also have another problem, I keep being prompted to install a 120kb OTA update, if I agree it installs and restarts the tablet only to be greeted by a broken android symbol at boot?
I am now just ignoring the OTA update request.
Thanks.
Same here, using 1.6 pre release.
I noticed that the OTA zip file is downloaded to your root folder, also tried installing it via CWM but I get an error...
So I removed the RKUpdateService (I think) manually, seems it got the rid of the anoying message so far.
Originally posted by MilesUK View PostI am now running the wifi version of 1.6 and can confirm that I no longer get the kernel wake lock problem.
Thanks.
Thanks.
New problem:
My NAND flash memory got stuck and I can't read or write data.
In Settings -> Storage it just says "Estimating..." on every "category".Phones: Samsung Galaxy S5, Samsung Galaxy S3, ZTE Blade, Samsung Galaxy Y, Nokia Lumia 520, iPhone 4, iPhone 3G, iPhone 2G.
Tablets: Pipo M7 Pro 3G, Toshiba Encore WT8-A-102, iPad 1 3G, Nexus 7 2012 (sold).
There are currently 2059 users online. 4 members and 2055 guests.
