Where are changed settings stored?
Originally posted by jamaroney View PostI have an MXQ Pro Quick Play (S905). When changes are made via the "Settings" UI, where does Android store those changes (so they're preserved on reboot)?
Thanks - let me be more specific. Via the UI, I changed the video resolution from its default, but when I scoured the databases afterward I couldn't find any relevant settings, default or otherwise. I then used Root Explorer to search for all files that had just recently changed, but came up w/ nothing applicable. Clearly, the changed info must be stored somewhere, otherwise it would revert to default on reboot. But I haven't found it.
Given that the location of stored settings files varies among different Android devices, I was hoping that another user of the same or similar device might have dabbled in this area.
Some of the display settings are written in cache. Like if I boot into twrp from an utility app, and boot to system after completing twrp, my position settings revert to stock, and go back to the default to auto adjust best resolution. Once I go and adjust position and set my display to 1080p, the default auto adjust best resolution, changes automatically back to my setting of disabled.
So, if cache you will need to backup all of the settings cache as well.
There are currently 2902 users online. 0 members and 2902 guests.
