????? (Likely for 2/16 ram/rom)?????
aml_7.12 s912 Frankenstein 3.2 (AOSP 64 bit) Lite version... 426MB size (ATV only...?).
aml_7.12 s912 Frankenstein 3.3 (AOSP 64 bit) Full version... 492MB size (ATV only...?).
aml_7.12 s912 Frankenstein 3.3 (AOSP 64 bit) Full LP version... 617MB size (ATV only...?).
Vasily_5 Developer at 4PDA.ru
*** Have tried it, so tweaker Beware......***
**** Soft-Bricked my H96 Pro+ v5 ****
http://4pda.ru/forum/index.php?showtopic=764998&view=findpost&p=9685074 4
"Default is Russian, European time is Moscow +3. The format is 24:00.
Kernel kernel patch. kernel support init.d.
Fix init.d. scripts have been added to the folder to speed up the system.
Fix GPU frequency increased.
Fix the Temp folder in the system.
Fix build.prop System.
Fix overclocking of TCP IP 4/6 protocol buffer.
OpenGL version 3.2 modules added.
Boxing identification spelled out "NVIDIA SHIELD Android TV"
Prescribed support for 2160p 60 4k VIDEO mode.
Voice Search Works with remote control G10, G20.
Added work from the camcorder. I have a Logitec C170 verified. Also control voice search through the camera.
Ad blocker, rewritten in the Host file blocking advertising sites and a banner.
Added some scripts relevant for today.
Installed YouTube TV. With the possibility of current updates.
Well, the X-plorer program. Wink TV version 64 bit. It is also possible to install 32Bit version.
SuperSU is already integrated in the firmware. Root rights.
Auto Frame Rate is built into the system without the need for an additional AFRd program.
Replaced Screen Server with "Aerial Dream TV".
Etc. ....... You
can watch the video review of the firmware on my channel.
Lite version :All Google removed
The firmware is completely cleared of unnecessary Google Play Market, Google tracking, Telephony, Contact Sync. Calendar, calculator. Etc. any Google-lyatina ...
Firmware Created to watch (KINY) Movies and TV.
Well, respectively, Films through the HD Videobox programs. KinoTrend. Cinema HD. torrent links.
The firmware is suitable for TV boxes with an Amlogic s912 processor. DDR3 / 4 ( for LPDDR3 boxes. It is necessary to check )
It is difficult to list everything by box names, Mecool BB2 / PRO. Mecool M8S. / PRO, MECOOL KM8 P, Mecool KM8 PRO. Tanix TX92, Tanix TX8. VORKE Z1, VORKE Z6, VORKE Z6 PLUS, YOKA KB2, X92, M96X / PRO. Transpeed M96X / Plus, Tronsmart Vega s96, the whole list is difficult to continue."
" We install the firmware USB burning Tool through the computer.
We flash the box through the Power button. Be sure to hold the Power button or the Reset button more than 7%. It personally took me 40-45 seconds. If it does not work, the cable jerks without shutting down the program.
The app is updated independently of the Google Play Market.
I will make separately the full version with Google Play "garbage" if there are any.
But this is the first assembly as it is written in the description purely for Cinema and TV views.."
Download firmware LAN 1000Mb.
Frank 2020 LITE Andorid_ (AOSP 64Bit 7.1.2) Vasily.img.7z
https://mega.nz/file/G...TqfwtZiIIslTW8tAm4USb4
Frankenstein 3.3 Full (ATV?) is now available.
Frank_3.3_2020_Full_Andorid(AOSP_64Bit_7.1.2)Vasil y_5_2020.05.30_LP.zip
https://mega.nz/file/zOQUjCTT#RB4wjB...T6ZI54JyMQId2s
firmware LAN 1000Mb
Frank_3.3_2020_Full_Andorid (AOSP_64Bit_7.1.2) Vasily_5_2020.05.30.img.7z
https://mega.nz/file/CJ0xjRRQ#8W4TRq...zKWq_2QXwK9JGI
