[ROM] aml_7.1.2_s912 Universal Firmware Frankenstein 2.3 Evolution Mod
Hi ReaperMan! thanks for the wonderful firmware. Is there anyway I can keep the launcher to Light home launcher?
It keeps going back to the main lanucher. Also, I installed a sports tv app but it won't turn on, it says to turn off the Ad blocker which I didn't install; is there a way to turn off this Ad blocker as well?Last edited by MickeyMouse; 10 October 2018, 15:01.
@MickeyMouse,
It's not my firmware (Untested by me)...so no kudo's to me.
Check your settings...Look to see if "Home" label is listed. Select you preferred launcher...should stick.
As for Ad blocker, the dev may have modified the "Hosts" file to prevent parasitic sites(ads) or included an Ad blocker...better to refer to 4PDA for accurate info.
Originally posted by thewebexpert View PostI tried it, seems to be an early rip off of atvxperiance. I looked at the build properties and it referenced that ... does not work with h96pro plus, no wifi.
You say it is an rip off ROM by looking at the Build.prop?
Sorry but then the most roms are ripp offs.
Neomode
Originally posted by loulapirate View Post
Thanks, i have bricked one pcb so i am carreful
There are currently 2348 users online. 0 members and 2348 guests.
