Android Tv Box Cooling fan and Acrylic Case
The Acrylic Thickness in 3mm and the software use is corel draw x7. This is for Tanix TX5 Pro,Tanix TX3 Max, Tanix TX3 Mini, Tanix Tx2 Download http://www.me...Last edited by eRainbow; 27 September 2018, 10:41.Tags: None
Originally posted by toto4d View PostCool video eRainbow. What app did u install to show the live CTemp on the home screen like in the video? Btw what's the cost that u spend to make the casing?
This is the application i get to monitor the temperature sir https://play.google.com/store/apps/d...daaan.cpufloat.
Originally posted by eRainbow View Post
It will cost $ 6.00 here in the philippine for the acrylic and for the rasp berry fan $ 1.00 but i dont know in the other country how much the cost for lazer cut for acrylic try it sir if you own tanix tx3 mini it will work very well for ventilation d best ever the android box did not hang or stop.
Originally posted by bradbradford View Postoh & also you are turning your box into an uneeded filter for dirt & dust, then moisture collects in the dust & contacts of the chipset & cls possibly short it out n fry it. only need a tiny 30mm or less fan n it will cool just fine cuz these boxes have no ventialtion n thats all they need.
I know you can't do this or ever make a better good looking and working cooling.
i dont make a trash looking and not working that why it is awsome.
I made this for people want to make a good cooling for thier tv box it is need so you can use the tv box for long operation did you really watch it ihas a 30mm fan and 80mm fan for choice and i have the material to build it without high cost i just share it .
Nice job mate, some people are ignorant that some parts of the world may have a different climate as where they live, and that drastic cooling measures are a must.
Looks really good
Originally posted by soldiaz View Postdid you use temperature conttroller? There are several, I would pick up 60 degree Celsius at which controller opens for cooling. Any suggestions?
A box without fan will run about 50°C on idle.
A Mecool M8S Max with built in fan will not go below 39° on idle
I have modified many boxes with a large heat sink and 100x100mm fan built underneath, sucking the air out through a 70 mm hole I cut in the bottom plate, and they would run about the same temperature with fan running constantly
There are currently 2064 users online. 1 members and 2063 guests.
