Android Tv Box Cooling fan and Acrylic Case
Originally posted by Jancales View Post
Can you please post some links to some of those posts?
this is the Link :
https://forum.freaktab.com/forum/mai...8-custom-cases
but i think you must ask User "BowerR64" with PM , to post Pictures again ,
greetings / gefattern
Better to buy a new one than try to repair it. These parts are cheap and not even worth repairing. WhatsApp GB
Originally posted by jasonroy View PostThat is come insane cooling, as I would like to think absolutely unneeded. These chips can run hot for quite a long time at 60c. same with PDAs. I put a small fan in mine cuz it was at 65-70c n now its at 45. only a little 30mm fan.
Hi ,
without cooling , with much better ,
Yes this is standard box.
With a large heat sink got it down to around 70°C and adding a fan in suction mode under the box to about 60°C
Take note this is running Kodi 17.1 I think, which was pretty heavy on processor load, but the average budget box without any modification will run high seventies whatever streaming app you use.
Tested a Magicsee N5 Max a few weeks ago, and with StressCpu it would be at 75°C within less than 2 minutes.
It would then stay stable at the temperature, but throttle processor frequency. After 5 minutes it would run at 1200 Mhz.and go as low as 1000 Mhz
better would be a little bit cooler , but for Thailand , if you can permanently hold the 60 degrees , would be good ,
my RK3399 runs always about 40 degrees , but i live in Germany ,
further good luck / gefattern
That is come insane Hot, as I would like to think absolutely needed active cooling for prolong use for child rhymes run over ~3 hrs or less
These chips can run hot for quite a long time at 60c or 70c ,so i put a small 5 volt a little 30mm fan it now its at ~40 to 50. only.
Tanix TX9 Pro TV Box MOD with Active Cooling-[video]
There are currently 2739 users online. 1 members and 2738 guests.
