[ROM] Minix Neo U9-H SCV1 ATV - Android 7.1.2 ( Android Tv Version )
Originally posted by blackrider View PostAny other person having issue of no sound or is it just me? After flashing the ROM, on initial boot there was a slight sound where one is required to select language of choice. After going through the installation process, sound disappears. I didn't modify nor change anything at all.
Originally posted by blackrider View PostThe issue was that I have Minix A2 remote plugged in so sound gets sent to the remote automatically. Once I unplugged the usb dongle, sound was restored.
Any idea how I may ensure sound doesn't get sent to the A2 remote?it needs to be fixed in the source.
Max i could do is remove all remotes from sources but... i wont since it will affect other stuff
For now running TV OS android v6
@superceleron Maybe a stupid question, but do I first need to download and install the MINIX NEO U9-H Android 7.1 Nougat firmware ... and then install the [ROM] Minix Neo U9-H SCV1 ATV - Android 7.1.2 ( Android Tv Version ) ?
Or can I go right away "above" my old TV OS android v6 (all of this using the USB burning tool of course)
Thanks in advance for the new rom
Greetz from BelgiumLast edited by Phil Maes; 24 October 2018, 07:34.
Originally posted by antonio6o6 View Postcan you tell me the wher i can get this file TV OS android v6 so i can teste on my minix neo u9h
under "download"
the other links you see are still down (minix forum)
superceleron I have successfully used a modded 1080 netflix on ATV v6 (not your rom), until a month or so ago...than it stopped; at that same time, i switched firmware, wanted to try official 7.1.2...i'm still on it...works fine for me as a firmware, but ran into your ATV and wanted to give it a try...at this point i'm asking whether Netflix 1080 works on your ATV or netflix has dropped all boxes but Nvidia Shield, that i read somewhere?!
Originally posted by Lundy R View Postsuperceleron I have successfully used a modded 1080 netflix on ATV v6 (not your rom), until a month or so ago...than it stopped; at that same time, i switched firmware, wanted to try official 7.1.2...i'm still on it...works fine for me as a firmware, but ran into your ATV and wanted to give it a try...at this point i'm asking whether Netflix 1080 works on your ATV or netflix has dropped all boxes but Nvidia Shield, that i read somewhere?!
Now the phone one.. i have ear'd its still working, a modded one, dunno if its true or not!
I'm happy with this rom...superceleron has done a clean superb job...
having said that, i noticed smth weird regarding kodi...
i was watching smth, and the box shut off, rebooted by itself...
it was fine after the reboot, i was able to finish watching the file...
this has happened two times, different files, different days...
I wonder if it is a memory management issue...
other than that, it runs fine
There are currently 1961 users online. 0 members and 1961 guests.
