[ROM] Minix Neo U9-H SCV1 ATV - Android 7.1.2 ( Android Tv Version )
    Is this rom still working fine? I'm still running the original Android 6 firmware on my Minix U9 so I was wondering if this would be a good upgrade. Does HDR work in Kodi with this rom?
      I'm trying to install this ROM on my Minix U9-H.
      I've downloaded the installation ZIP file and unpacked the img file. The USB Burning tool shows that it is succesfully connected with the U9-H.
      But I can't import the image when I click: File > Import Image.
      Then I can browse to the folder where the *.img file is located, but the program doesn't show any file with the *.img extension.
      Even tried version 2.1.7.3 and 2.2.0 of the software. Both the same problem.
      What can I do to solve this problem?
        Not really solved the problem, but did a work around.
        I’ve installed USB Burning tool on another computer and then I just could open / select the img file for import.
        Both computers run Windows 10. On the first computer I even removed and re-installed the USB Burning Tool software, but still the same problem. Want to share my experience to help other people.
        Now I'm testing the software. Seems to work nice and smooth.
          I have tried all the Minix U9-H Firmware and they all the ones on 7.1.2 and have a name beginning to SCV1-ATV-
          I have all the same issue with a Minix A3 remote, basically the error message :
          "Android TV Remote Service has stopped", keep appearing and it appear so often ... that the Android TV is allmost impossibe to use it
          Does someone know a cure to this ?
          thanks
            Finally I think I find a fix, you install your Androud apps, then they will automatically update it include the Android TV remote service. Then you disable the auto update from google play and finalky you uninstall the update of the Android TV service and you reboot
              i just freshly installed this firmware as I want to use the Minix for remote stream client.
              I am connecting my Xbox 360 Wireless Controller via USB Receiver to the USB OTG port of the minix. I can control the menu with the Gamepad but this is exactly the problem, when in a Game you simoultaniusly control the game and the menu and therefore press a button to exit a game. Any knows how to fix this ?
              Glad for any input
                Hi, Is it possible for someone to reupload it as the download doesnt seem to work
                  i will see if i can find my files and upload it again.
                    Fixed the download link.
                      Thank you appreciate it
                        Hi there guys and girls, one more rom/fw for you all!
                        This time is Android 7.1.2 ATV for this box.
                        Many thks to gearbest for sending me the device to play
                        Many Thks to my beta tester trebor
                        READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
                        Changelog V1:
                        • Ok i could do a nice changelog bla bla bla... but i really don't have the time and mood to do it...
                        • Is as close to a "true" android tv rom as possible and some bugs fixed....
                        HALO , PLEASE COULD MAKE THE ROM LINK AVAILABLE ?
                          Yes, later today i will post a new link.
                            Fixed the link
