New hardware mk808/mk808b clone. blue HTC board anyone seen this before?
    i bought this mk808 on **** the other week, it came from hong kong. well, it is advertised as an mk808, but it is an mk808b clone i think. however, i cant find an image of this hardware model anywhere so i thought i would post some photos here to see if anyone has seen this model yet? im brand new on the forum, only because i have encountered something to contribute.
    it has an rk3066 dual core with elpida j4216 set, hynix memory on the back of the board, the board is blue and has htc_1011 printed on the board between the elpida chips. it has only one wifi antenna. i am pretty sure it is a different model. photos:
    https://plus.google.com/photos/10302...089?banner=pwa
    images
    no link, just pictures.
      Hi Thomas,
      seems I have the same device that you, see here:
      Now my question is: Which firmware is installed on your device?
      Andi
        AW: New hardware mk808/mk808b clone. blue HTC board anyone seen this before?
        Hello,
        This is the first Rockchip RK3066 which has a AP6210 Wi-Fi chip.
        Never seen this before. There is at the moment no Custom Rom out there.
        Neomode
          Originally posted by neomode View Post
          Hello,
          I think there is a Custom Rom. Please look at this thread:
          It is Finless 2.1 with the Stock Kernel.
            so i have toyed around with multiple roms and have discovered two candidates. the finless 1.7 rom and the minix neo x5 rom. both are unstable and have incorrect drivers. the minix neo works because it too has a broadcom wifi chip but it is an earlier model hence the instability. the tronsmart t428 & mk908 both have the correct wifi chip but are quad core roms. i need a finless rom that is not just one .img file so i can copy the driver for the wifi into both working droid roms. other things i noticed, antutu benchmark will crash this stick and so will xbmc, blackmart will install, but wont run & it crashes the stick too.....weird. also, root folder access acts strange. says it is rooted, but some apps that require root crash the system.
            both working roms are available here on freaktab.
            looking for an mk908 or tronsmart t428 finless rom that i may be able to steal from and paste into his 1.7 mk808b rom. hey, it is worth a shot...
              Originally posted by andip71 View Post
              Hi Thomas,
              Andi
              i used the finless 1.7 mk808b rom and the minix neo x5 rom. both work, kind of.
                May it is possible to Test the MK908 Rom
                On your device. I know it is for a quad core stick but I will test it and see what happens.
                Neomode
                  RK3066 with AP6210
                  Rikomagic have releesed a firmware for the MK802IIS8B with the AP6210 so its out for the RK3066.
                  Shenzhen Rikomagic Tech Corp.,Ltd-----Android TV BOX, Media player, Digital Signage Media Player,signage player
                  Its two dowloads for the MK802IIS8B one for the old version and one for the AP6210.
                  Direct link for AP6210 http://www.sendspace.com/pro/dl/1d4eid
                  The normal have updated audio ouput settings with HDMI passthrue that is working.
                  MK802IIIS/BT
                    I can confirm, this combo sort of works for me.
                    I have stable and fast WIFI. Bluetooth is not tested as I do not need it.
                    However, I experience random hot reboots from time to time, not yet sure if this is the power supply or the firmware. But I will monitor this closely and let you know.
                    So far, I am quite happy with Finless 2.1 and the stock kernel.
                    Andi
                      Andi
                      i swapped psu's thinking what you just mentioned about crashing & overheating. the psu swap made no difference. it is the firmware i am sure.
                        Neomode
                        yeah, i am giving that a shot now. expecting a fail or linux penguins. sure would be nice if i could just boot to a terminal.
                          thanks, testing today.
                            confirmation of working & tested rom
                            hi everyone.
                            this one works, and works well. wifi @ 58mbps, bt on & working with s9 & ps3 dual shock. xbmc flawless, antutu stock benchmark score of 7201. 1080p kernel. 4.2.2 is very nice.
                            direct download link: http://www.sendspace.com/pro/dl/1d4eid
                            will continue to load & test system. EVERYTHING WORKS GOOOOD!
                            thank you to the individual who posted the link in this thread. i am confirming that this rom is best yet. no crash/overheat. oh and it recognizes a 1tb 2.5 usb drive without a powered hub in the otg port!
                              many thanks to mattwest
                              thank you for the link dude. you rock.
