Android TV update for wasser firmware 3.0.6
Originally posted by welder_pb View PostLast edited by tsynik; 22 November 2018, 16:04.
Originally posted by tsynik View PostHi, guys!
Here is the Android TV update for great wasser 3.0.6 fw:
Google Disk
What changed:
- spoof as Nexus Player for Google Play
- russian translation update in Android Settings and framework-res.apk
- Android TV UI sounds
- DPI set to 293 (align 2-line cards to bottom screen edge)
- Google boot animation
- LeanKey Keyboard Pro as default keyboard
- Leanback Settings launcher row: Settings / Reboot / Shutdown
- added AppDrawer for mobile launch intents
- disabled navigation bar
- initial settings scripts in /system/etc/init.d
- AceStream autostart (remove file autostart.acestream at /sdcard/IPTV to disable)
- updated Superuser, busybox and timezones
- custom background in Leanback Launcher and AppsDrawer
- new NFS automount script (configured via /sdcard/IPTV/autostart.nfsmount file contents)
- removed useless permissions (Play Store compatibility with TV apps)
- custom TV settings (mainly for Wi-Fi icon on Home screen and Search and Home screen setup)
Network install (via adb):
Linux / macOS
- download ATV_update_EN.zip and install script adb_update.sh to same folder on PC
- rename ATV_update_EN.zip to ATV_update.zip
* script adb_update.sh and archive ATV_update.zip must be in same folder
- change permissions for adb_update.sh: chmod 755 adb_update.sh
- run adb_update.sh and enter IP of your device
Windows
- download ATV_update_EN.zip and adb_update.win.zip
- extract contents of adb_update.win.zip to ATV_update.zip location
* script adb_update.cmd and archive ATV_update.zip must be in same folder
- run adb_update.cmd and enter IP of your device
* script will ask IP-address to connect and will launch update process on success
* network copy over adb is slow: after message [1] Copy archive to device...
there will be no other new messages for a long time (5-10-15 minutes).
Be patient - wait for [4] ... message and "DONE"!
Recommendations:
- make full device reset via Android Settings after update (all data on internal storage will be erased)
- disable Google Play Store autoupdate and keep original Android TV launcher and YouTube for Android TV:
new versions from Store have issues (no recommendations in Launcher and sound problems in YouTube 2.x)
* you can update all other apps
Have fun!
[QUOTE=tsynik;n746983]Hi, guys!
Google Disk
What changed:
great rom, thanks Tsynik. Anyway of doing the same update with Wasser's beelinik R89. Thanks again
Originally posted by minonano View PostSorry this link
https://forum.freaktab.com/forum/tv-...or-beelink-r89
i intall wasser 3.0.6 fw stock 5.1.1 for minix neo x7 after sucess lan not working only wifi active
so i can install Network install (via adb)
can you have video manual or step by step
thank and best regard!
Originally posted by Lachty View PostHi all,
I try update to android tv, and last commands in CMD was: Cleanup... and Have fun! (not DONE).
I can see in my minix only logo wasser still. What I can do?
I did unpack to boot.img and kernel.img but i cant unpack kernel.img to modify config settings....on system.img there are the rtl8723bs needed files
Enviado desde mi SM-G975F mediante Tapatalk
Originally posted by ikerg View PostIs there anyone that could modify this fantastic rom to accept rtl8723bs wifi & bluetooth?
You can read here how to compile a kernel for RK3188, perhaps it's useful.
But the kernel version and drivers have to be very close to the stock ones otherwise it won't boot.
You can't unpack a kernel, it has to be compiled from source code.
https://forum.freaktab.com/forum/tv-...ost#post510934
There are currently 1471 users online. 1 members and 1470 guests.
