Beelink GT1 MINI TV Box with Voice Remote Amlogic S905X2 Android 8.1
    Beelink GT1 MINI TV Box with Voice Remote Amlogic S905X2 Android 8.1, Dual WiFi,gig Lan, USB3.0, BT4.0
    Click image for larger version  Name:	20181018104530_48352.jpg Views:	1 Size:	83.5 KB ID:	748750
    Specification General
    Brand: Beelink
    Model: GT1 MINI
    Type: TV Box
    System: Android 8.1
    CPU: Amlogic S905X2
    Core: Cortex A53,Quad Core
    RAM Type: DDR4
    Max. Extended Capacity: 32G
    TV Box Features: 5G WiFi,Portable
    Media Supported
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: AVI,DAT,ISO,MKV,MP4,MPEG,RM,WMV
    Audio format: AAC,FLAC,MP3,OGG,RM,WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    Product Details
    5G WiFi: Yes
    WIFI: 802.11 a/b/g/n/ac
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: AV,DC Power Port,HD,LAN,TF card,USB2.0,USB3.0
    Antenna: Yes
    Camera: Without
    Language: Multi-language
    HDMI Version: 2.0
    Other Functions: DLNA,ISO Files,Miracast
    Power Consumption.: 6W
    RJ45 Port Speed: 1000Mbps
    Firmware Information
    System Bit: 64Bit
    System Activation: Yes
    Power Requirement
    Power Type: External Power Adapter Mode
    Battery Information
    Remote Controller Battery: 2 x AAA Battery ( not included )
    Dimension and Weight
    Product weight: 0.1250 kg
    Package weight: 0.3450 kg
    Product size (L x W x H): 7.70 x 7.70 x 1.70 cm / 3.03 x 3.03 x 0.67 inches
    Package size (L x W x H): 15.70 x 11.60 x 5.90 cm / 6.18 x 4.57 x 2.32 inches
    Package Contents
    Package Contents: 1 x TV Box, 1 x Power Adapter, 1 x HDMI Cable, 1 x Remote Control, 1 x English Manual
    Gearbest
    I wish that Amlogic would officially announce the S905X2 so that we can see what HDR specs it supports.
      This should give you some idea:
      http://freaktab.com/news/749019-comp...specifications
        the AV port is 3.5 jack or optical ?
          Found over at Geekbuying:
          $72.99 after coupon: SSFFFZLY
          $57.99 after coupon: GGZKKFQG For 2GB/32GB
          $67.99 after coupon: MUBWQCUW For 4GB/32GB
          Geekbuying
            On its way should be happen real soon
              Today we can have a look at the Beelink GT1 Mini 905x2 4/32GB, Dual WiFi, Gig Lan, BT and wireless remote
              The usual well presented Unit from Beelink
              You will Note this unit has a Wireless Remote using a Dongle and also BT on the AP6255 WiFi Chip
              Let's have a look at this Box of Trix and see what it has to offer
              The Box:
              Remove the Lid: Well presented:
              What we have in the Box:
              Ports:
              Remove the base: Not a lot, but we see Reset Button.
              Out with PCB: One of them groovy looking antenna's
              More to come soon
                one is coming
                  More on the GT1 Mini 905x2 4/32GB, Dual WiFi, Gig Lan, BT and wireless remote
                  Good simple look, small and very easy startup with Wizard.
                  Wifi and Ethernet appears all good.
                  Easy setup to Google update Apps, install testers.
                  GT1 Mini is running Normal Android, No ATV here, (yet) normal Google Play Store etc.
                  UI and feel is the Beelink typical launcher and it works.
                  DRM is Level 3: Videophiles may be concerned, Netflix etc.
                  Voice remote working well, Push, Hold Microphone Button and Speak.
                  Temperature also excellent nothing over the top.
                  In settings we have Droid and More Settings to fiddle.
                  Upper and Lower task and Notification Bars
                  Also the the GT1 Mini 905x2 has Root access:
                  Good startup appears zippy using both Logitech k400 or Remote easy navigation
                  fast ram in this unit i feel
                  OTA update was detected while doing the Wizard thing, let that happen, good to see support already.
                  Front indication is a small White Dot (LED), looks good, different from the red, blue eye burners we usually tolerate.
                  Power supply 5vdc at 2 amps.
                  On with the Show and tell,
                  A reminder, Benchmarks are just a Guide to the potential of the unit under test. results may differ.
                  Wizard UI, Install apps etc: On Home Screen clicking Power, Speaker and WiFi, BT etc is a direct link to those setting: Holding Menu Button Background Change.
                  Upper and Lower Bars:
                  Before and After Update
                  Some more Settings:
                  More Settings:
                  Ram and Storage Truth:
                  Ethernet:
                  DRM Info L3:
                  CPU-Z:
                  Geekbench CPU and Compute:
                  3DMark:
                  SD Card Test: Coode speed going on here
                  Antutu 3D:
                  Beenlink File Browser:
                    One of the installed programs is app market with a selection of recommended Apps, installing Netflix and Amazon Prime from this App both appear work be it SD only,
                    Updating Netflix from the apkpure website has now given us a massive 960 x 540 looks even better
                      Does this support Microsoft Playready DRM?
                        Of course not.
                        It doesn't show in the screenshot and you need AndroidTV for it to also work.
                          Remote - air mouse???
                            Voice remote works well,
                            No AIr mouse or mouse function on the remote alway have the Logitech k400 for that
                              That remote ......with regular android
                              AZW- beelink do you see mistake??? Maybe I'm wrong ,but Beelink will lose race
                              • trebor
                                trebor commented
                                Editing a comment
                                It's only a remote,
                                Many items out there that you maybe able to find for a minimal price I feel
                                Again all up to the individual and their requirements
                                Lets see what happens when a Dev gets into it, anything is possible
