Beelink GT1 MINI TV Box with Voice Remote Amlogic S905X2 Android 8.1
Guest
Here's an initial build of TWRP 3.2.3-0 for the Amlogic u211 reference hardware: twrp.u211-3.2.3-0.img
It's built with the twrp-8.1 minimum OMNI branch and is using a prebuilt 112N0 GT1 Mini kernel. I'll be creating a twrp-8.1 branch in the Amlogic repository for this along with updates for the q201 and p212 reference hardware.
Originally posted by Magendanz View PostHere's an initial build of TWRP 3.2.3-0 for the Amlogic u211 reference hardware: twrp.u211-3.2.3-0.img
Can I ask you to build twrp for x96max?
it is a partition table x96max
Code:/boot emmc /dev/block/boot /dev/block/mmcblk0p11 flags=backup=1;display=Boot /recovery emmc /dev/block/recovery /dev/block/mmcblk0p6 flags=backup=1;display=Recovery /param emmc /dev/block/param /dev/block/mmcblk0p10 flags=backup=1;display=Param /system ext4 /dev/block/system /dev/block/mmcblk0p16 flags=backup=1;display=System /vendor ext4 /dev/block/vendor /dev/block/mmcblk0p14 flags=backup=1;display=Vendor /data ext4 /dev/block/data /dev/block/mmcblk0p17 flags=backup=1;display=Data /cache ext4 /dev/block/cache /dev/block/mmcblk0p3 flags=backup=1;display=Cache /bootloader emmc /dev/block/bootloader /dev/block/mmcblk0p1 flags=backup=1;display=Bootloader /reserved emmc /dev/block/reserved /dev/block/mmcblk0p2 flags=backup=1;display=Reserved /env emmc /dev/block/env /dev/block/mmcblk0p4 flags=backup=1;display=Env /logo emmc /dev/block/logo /dev/block/mmcblk0p5 flags=backup=1;display=Logo;flashimg /rsv emmc /dev/block/rsv /dev/block/mmcblk0p12 flags=backup=1;display=RSV /tee emmc /dev/block/tee /dev/block/mmcblk0p13 flags=backup=1;display=Tee /crypt emmc /dev/block/crypt /dev/block/mmcblk0p9 flags=backup=1;display=Crypt /misc emmc /dev/block/misc /dev/block/mmcblk0p7 flags=backup=1;display=Misc /odm emmc /dev/block/odm /dev/block/mmcblk0p15 flags=backup=1;display=ODM /dto emmc /dev/block/dto /dev/block/mmcblk0p8 flags=backup=1;display=DTO /external_sd auto /dev/block/mmcblk1p1 flags=wipeingui;storage;removable;display="Externa l SD" /usb-otg auto /dev/block/sda1 flags=display="USB OTG";removable;storage
Guest has done some magic also
In the spirit of the Pure Nexus Project, these Nano and Stock Nexus ROMs prove that less can be more. The goal is to keep true to Google's vision and use the bare minimum of OEM or third-party apps or add-ons, which can be added ? la carte by the user as needed. These ROMs also serve as a foundation for TVStock Nexus ROMs,
Originally posted by natzen View Post
Latest updates 1140
Repair:
1: Fix browser playback video splash screen problem
2: Fix mouse movement screen problem
3: Fix settings click on external storage option flashback problem
4: Optimize TVSettings
5: OTA has been pushed
Beelink GT1 mini latest firmware build number: 114N0 release http://www.bee-link.com/data/attachment/forum/201812/28/162847tax97g1e313y9sgg.jpg Firmware version: Build number 114N0 System: Android version 8.1.0 Repair: 1: Fix browser playback video splash screen problem 2: Fix mouse movement screen problem 3: Fix
Originally posted by Venusflytrap View PostI'm having a tough time deciding what is a better overall unit. This Beelink or the X96 Max. Thoughts?
Bit of a coupon deal saves a few Bucks for those who have not taken the Plunge into the 905X2
2019.01.09 ~ 2019.01.31 Beelink GT1 MINI TV Box with Voice Remote /4+32G $62.99 coupon code: GBCN432: amount: 50 (https://www.gearbest.com/tv-box/pp_009974590664.html?wid=1433363&lkid=19114546) BUY NOW www.gearbest.com (https://www.gearbest.com/tv-box/pp_009974590664.html?wid=1433363&lkid=19114546)<-clickme
Lots of Custom roms about, might be worth a look.
Originally posted by uscool View Post
Beelink probably because it gets updates often and also you can flash the custom ATV rom on it but it costs more , the X96 Max is cheaper with same spec really hopefully custom ATV rom can be made for this
There are currently 2022 users online. 3 members and 2019 guests.
