Developer: tillaz87
Repost from:
Untested: Reported to work on H96 Pro+
- "Description:
This is Android TV it supports all variants of the GT1 + other q201 boxes, which means this firmware is much different to what these boxes ship with (Tablet UI)
Andriod TV is what Google intend to be on a television
Included:
Recant Changes: v10.7 Final release
- System re-partitioned = 1 GB Extra for apps/data
- 4K YouTube + 60fps enabled
- Enabled ATV Recant apps + Assistant (Double press home button, Long Hold for assistant, can use this on phone for mic)
- Cyanogen homescreen clock/weather (Configure from app draw cLock)
- Support for all Xbox/Sony Gamepads + Fixed select + home For Xbox Controllers
- Fixed wireless Xbox 360 problem (left D-pad opening power menu)
- ATV remote service (support for this)
- Performance tweaks (RAM,CPU,IO) + init.d support
- Deodexed system, Ramdisk cleaned up, fully un-rooted, + removed from settings (root without prompt is a security risk)
- Beelink remote fully working (Short cuts: Settings, Kodi, Chrome, Youtube)
- Add back HDMI CEC settings (vorke removed it)
- Fixed antutu and other 2D/3D games that use unity
- Audio fixes aimed at antutu but for sure will apply elsewhere
- Magisk can now be installed + safetynet will pass no need for any patch/module
- Power menu now includes > suspend, shutdown, reboot, recovery (root not needed)
- Improved media playback + lip sync fixed + Amcodec fixed
- Updated Mali GPU driver + OpenGL 3.2 + Android extension pack (vorke use 3.0)
- Fixed unrecoverable from sleep after long periods
- Burn-in protection enabled (Oled TVs)
- framework is now 99% AOSP 7.1.2 N2G48C
- Code removed that was sending errors on home button press (linked to removed OEM stuff)
- Removed code from services for /sys/class/leds/fd628_dev/ (vorke hardware)
- Removed code from services that blocks play store updating (vorke)
- Removed code from services that hides app not responding dialog (vorke)
- Add missing DRM library's (L3) + Fixed mouse pointer size (vorke)
- Fixed Bluetooth audio stutter on QC9377+ AP6335 & AP4356 WiFi+BT fully supported
- Fix some freezing issues with 4k h265
- MINIX NEO A2 & Lite keylayouts added
- New wallpaper (flash StockWallPatch.zip for stock then clear data on leanback launcher)
- TWRP: credit Magendanz
- New Inputs setting (CEC)
- Power button settings moved to Inputs
- Port Ugoos playback settings (display)
- built Magisk root method in to TWRP (Advanced/Magisk root)
- Fixed TWRP reporting 5.1.1 OS, some zip like xposed fail because of this
- Busybox updated / fixed
- reverted some lib stuff
- Fixed auto frame settings?
- USB Camera fixed?"
"Read This Before Posting
- For root just reboot recovery then -> Advanced / Magisk root
- Look here if remote does not work with keyboard or Gamepad is not working
Problem with a video streaming app? Look here before posting- Support patch for Led clock on vorke devices (Flash this after rom)
- If you want to block ads use this or flash this
- For Bluetooth issues on QC9377 or LMT8830 flash this Do not use on AP6255"
Reposted here as another firmware option...testers beware...always a chance to brick your device.
