Rom: Android Pie for S912
    slimBOXtv 15.1
    Changes:
    • Added support for Bromite SystemWebView (download from the project website)
    • The AOSP keyboard startup icon is hidden
    • Replaced Setup Wizard (ATV)
    • Fixed issue with logging in to Google account
    • Updated WebView and Google Play service
    • Added additional Bluetooth settings with the display of the battery charge of the remote control
    • Increased logo and boot animation size
    • Added AOSP keyboard with Holo Blue theme by default
    • Adjustments to the operation of image modes
    • Added optimally configured Nova Launcher mod, activated as master (PIE)
    • Google services with less memory and CPU usage are used
    • Key reassignment has been modified in the Button Manager and is launched from the settings
    • Systematic amendments
    • Added support for Bromite SystemWebView (you can download it from the project site)
    • Hidden launcher icon for AOSP keyboard settings
    • Replaced by Setup Wizard (ATV)
    • Fixed issue with google account login
    Clean installation is strongly recommended !!!
    Download ATV or PIE
    https://slimboxtv.ru
    Historical (depreciated) info:
    (Links may have died-off)
    Pre - 2022
    Honors to devs who rescued users from Amlogic's handling of the powerful S912 Chipset.
    khadas.com
    Info 4Pda---Highwaystar
    https://4pda.to/forum/index.php?show...905729&st=1180
    Developer Bumerc:
    Mod 1: ATV9/64bit build, based on HighwayStar's 2020-07-07.
    >>download<<
    Davietpda has finally posted a beta of his awaited firmware.
    https://daivietpda.com/2020/07/rom-a...-amlogic-s912/
    The BETA2 supports ram 2G / 3G ddr3 and ddr4 wifi ap6255, ap6330
    Download: aml_upgrade_package_s912-pie-beta2.img
    Link 2: https://mega.nz/file/qF4X3YZR#iVUeUY...F5sRXfnYi92FBM
    Use Amlogic + USB + Burning + Tool_v2.1.7.0.exe
    As tested by Brahner(4pda)
    "+ There is no flicker in the Davietpda assembly firmware on 3/32 lpddr3 (tx9pro). The loader took from bumerc.
    + Consoles from h96pro plus and from the tx92 branch (z6, z6 plus, tx9pro, etc.). Both in the android, and the inclusion of the box
    "The amlogic S912 ram LPDDR3 updates added here: https://youtu.be/l0Swj9Suy5U "
    superceleron (Freaktab)
    [ROM] "Generic" SC ATV v1.0 USER/USERDEBUG - S912 Pie
    07-20-2020
    Vasily_5
    https://youtu.be/Lz4-dtWJvyc
    Mod from Davietpda beta 2
    The firmware is suitable for Two versions of boxes mecool bb2 / Pro version.
    https://mega.nz/file/vBJ2DIra#K_oslB...GYR6dyawe-vNCg
    sergej_a_g
    Port of Android 9 ATV By
    SLIMBOX ver 5.1 ATV & AOSP
    ATV
    https://yadi.sk/d/Oi_gX40053pRcQ
    AOSP
    https://yadi.sk/d/j48wIHbmNEW8CA
    2020-09-25
    lyubodelev
    Port_SLIMBOX-ATV-TANIX-TX9S-v8.3.2_to_Z69 + (LPDDR3) 500+ MB
    Works on H96 Pro+ 3/32 CZ v5(6?):
    https://4pda.to/forum/index.php?show...882984&st=7660
    ** Slimbox ATV to AOSP patch 191 MB
    Read review: https://forum.freaktab.com/forum/tv-...or-s912/page16
    https://mega.nz/file/FZgwVaSQ#GK3wQy...bsZx1ffo_dLuas
    ATV to AOSP Patch:
    Thank-you
    hi, can I make a 3/32 build for lpddr3 memory
      Sunvell T95Z Plus 3|32 lpddr3
        Облако Mail.ru - это ваше персональное надёжное хранилище в интернете.
        3ram S912
        2ram S912
        use airmouse USB
          I came accross the following android 9 Pie ROM that has been uploaded recently for the Khadas VIM2.
          The VIM2 is a S912 board designed for Android TV and Ubuntu. https://docs.khadas.com/vim2/FirmwareAndroid.html
          Download Link
          The rom is flashed by me with Am Burning Tool on my X92 3G/12G and it booted.
          The list that worked: Wifi, Ethernet, Bluetooth, Sound.
          What did not work: Front Display, 1 out of 4 USB ports, the remote.
          So far so good it runs smoothly.
            @larrywilson,
            To be on the safe side...check your system settings to confirm that your China Box is using the full 3GB of RAM. It may(?) be limiting your device at 2 GB of RAM.
              Hi,, would it work on beeliink GTI ultimate, 3, 32? Thanks.
                @diligent7771,
                If you can mod it, go for it! Khadas has put their base Android Pie for developers to use.
                @minonano,
                The developer(modder) mention making a 3/32 compatible version.
                LPDDR 3/4? gives error, % failed flash. You may "Brick" your device, be sure how to "UnBrick" your China Box before testing.
                  hi I know how if I have for the test I can try
                    i have in 4 pda
                      I modified and rebuilt the latest version, patched the bootloader for LPDDR3 memory, the tests were successful on my H96pro+ device, I will soon post it in a separate topic
                        Freaktab Rocks
                          hoo pity i have mine already done, well i will continue to add my changes/fixes to the sdk and then rls it.
                            LAN ON En Android, puede obtenerlo desde Configuración-> Más configuraciones-> Acerca de-> menú Estado.
                            https://cloud.mail.ru/public/2jiE/J5sqyTF9D WIFI ON lAN ON
                              Wake-On-LAN (WOL) is a protocol standard that allows your PC/Smartphone to turn on a computer via your local network or the Internet.
                              2) On Android, you can get it from Settings->More Settings->About->Status menu.
                              Enable WOL
                              DDR3 / DDR4:
                              update_khadas_pie_multiwifi_20200707_arm64_ATV.img
