Weird i can't see your posts... but if i go to you profile i can see them.
Btw they did fix it.
DDR4 chl: Rank0+1 @ 912MHz bist_test rank: 0 13 04 22 2b 18 3e 0d 01 19 36 23 4a 16 06 27 2f 1a 44 1a 09 2c 2d 19 42 693 rank: 1 17 00 2f 2a 16 3f 13 00 27 37 23 4b 1a 04 31 2f 1a 44 1f 07 37 2d 19 41 693 - PASS Rank0: 2048MB(auto)-2T-18 Rank1: 1024MB(auto)-2T-18
(jJsdio debug board detected TE: 145410 BL2 Built : 11:58:42, May 27 2017. gxl gc3c9a84 - xiaobo.gu@droid05 set vdd cpu_a to 1120 mv set vdd cpu_b to 1050 mv set vddee to 1000 mv Board ID = 6 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0+1 @ 912MHz - FAIL DDR3 chl: Rank0 @ 912MHz - FAIL DDR3 chl: Rank0 16bit @ 912MHz - FAIL DDR4 chl: Rank0+1 @ 912MHz - PASS Rank0: 2048MB(auto)-2T-18 Rank1: 1024MB(auto)-2T-18 DataBus test pass! AddrBus test pass! -s Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from eMMC, src: 0x00020200, des: 0x05100000, size: 0x00018400 Load bl33 from eMMC, src: 0x0003c200, des: 0x01000000, size: 0x00064000 NOTICE: BL3-1: v1.0(release):3348978 NOTICE: BL3-1: Built : 15:44:01, May 12 2017 NOTICE: BL3-1: BL33 decompress pass mpu_config_enable: ok [Image: gxl_v1.1.3221-2cfba69 2017-05-27 16:03:58 qiufang.dai@droid07] OPS=0x82 wdt: reset registers! 97 d2 5f 1d 50 c da 1e 23 59 ed 6 [0.677751 Inits done] secure task start! high task start! low task start! ERROR: Error initializing runtime service opteed_fast U-Boot 2015.01-g2966aaa (Jul 12 2017 - 19:47:43) DRAM: 3 GiB Relocation Offset is: b6eb9000 register usb cfg[0][1] = 00000000b7f5cae8 [CANVAS]canvas init
There are currently 4171 users online. 0 members and 4171 guests.
