Rom: Android Pie for S912
Originally posted by Massimo1993 View Post
@superceleron sorry to bother you again but do you have any other information that could be useful to davietpda developer in order to fix that freez/restart problem?
Not as easy as you might think, that was one of the reasons at the time made me go away from s912, to many different ram used and is impossible(well nothing is impossible just not practical) for you to support all in a single rom.
I have my roms done for a while now, proper atv rom etc but.. i just still did not rls it because of all this DDR ram difference issue.
Btw beelink ones are especially complicated on that subject.
Sorry only notice this now.
Anyway opening my h96 pro+ i did find there are 2x2 ram chip, i presume 2 are 1GB and 2 are 512MB, now i understand the problem you were talking about. At first i did think there was difference just between h96 models and instead there are even different ram chip in the same model. I am correct?
Originally posted by Massimo1993 View PostAnyway opening my h96 pro+ i did find there are 2x2 ram chip, i presume 2 are 1GB and 2 are 512MB, now i understand the problem you were talking about. At first i did think there was difference just between h96 models and instead there are even different ram chip in the same model. I am correct?
Originally posted by ppromo47 View Post
would you like to share the build for remaining devices, it worth testing.......
Going to be secureos, and 16 builds total... and then i will walk away from s912 and let it fade
8 builds QCBT and 8 BCMBT, from each 8, 4 ddr3/ddr4 and 4 lpdd3 and from that 4, 2 are "normal" and 2 are "atv".
So ye lots of roms.......... btw i will not support 100mbits ethernet.. or else that goes up a lot in terms of roms..
Also im not supporting any particular remotes, other than the 2.4g g10 and g10s and some other 2.4g remotes... on IR ones.. well i do not care!
Btw no beelink support on secureos builds, since looks like beelink boxes go haywire with it and cant read the secure key... go figure.
Boxes tested:- original 1º ever h96 pro ddr3
- a later h96 also ddr3
- a h96 lpddr3
- a tanix DDR4 (cant remember the model, does not have markings on it.. its a metal case), and works great all ram is detected fine
- Mecool M8S Pro L (lpddr3) widevine l1 and does not lose it, but does lose the eth since is 100mbits only.
- beelink GT1, does not boot stays in boot logo because it cant read the secure key...
- beelink GT1 ultimate, same as above and also only detects 2gb ram instead of the 3gb, i tested other ppl uboots and are all the same, like said beelink boxes are very peculiar.
So when they ready all of them, i will post it.
Yes i will be sharing it, i will create its own thread.
- a h96 lpddr3
will be be waiting for an update from you....
Originally posted by Massimo1993 View Posthertz-ota-eng.daivietpda.ddr3-ddr4-9377-beta3 not working on h96 pro+ with ddr4 v3 still same freez/restart problem, i've asked the developer on his facebook account if he will try to do something about.
u-boot_ddr4-cl16_v3_board.tar.xz
Originally posted by bumerc View Post
Originally posted by superceleron View Posthmm should i do secureos? i do not see the point for L1 devices... you guys won't take advantage of it anyway.
What you guys think?
Thanks again for your work.
I still think s912 deserves A10 / A11.... its still better than most of the S905XX
Originally posted by ppromo47 View PostI still think s912 deserves A10 / A11.... its still better than most of the S905XX
If you want a longer software support x86 mini pc are the way to go.
When i did have some money to spend i bought a 130€ x86 router with an intel 3865U and the software support and variety is just astonishing compared to arm stuff.
There are currently 2379 users online. 1 members and 2378 guests.
