Rom: Android Pie for S912
I have tested the rom of the friend Amlogic s912 Android Pie ATV by DaivietPDA and it is perfect to the point that all the other rooms are rubbish next to this it is functional without flickering pin problems fast Youtube vance on prog tv beta on netflix HD on
Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
https://daivietpda.com/2020/07/rom-a...-amlogic-s912/
https://drive.google.com/file/d/1l55...Vj32ykzm4/view
Rom ATV9 Android 9.0 Cho Amlogic S912 By DaivietPDA excelent good
Originally posted by ReaperMan View PostLast post not approved...or magically deleted?
Since last time Freaktab was hacked...things have fallen apart...a bit.
Update to davietpda modAs tested by Brahner(4pda)Davietpda mod beta 2
"+ There is no flicker in the Davietpda assembly firmware on 3/32 lpddr3 (tx9pro). The loader took from bumerc.+ Consoles from h96pro plus and from the tx92 branch (z6, z6 plus, tx9pro, etc.). Both in the android, and the inclusion of the box+ WiFi (qc9377) and 1000 ethernet work- But one of the usb ports does not work for me- bluetooth does not work, it does not turn on"
Originally posted by ReaperMan?Second try at posting (Moderators ..any problems with post could be fixed)?
Davietpda has finally posted a beta of his awaited firmware
LPDDR3
"The amlogic S912 ram LPDDR3 devices will be supported in the next few days when I have a box to build
The following updates will be added here: https://youtu.be/l0Swj9Suy5U "
EDIT : It seems to be 32 bit ROM.Last edited by ppromo47; 10 July 2020, 20:54.
bumerc there is a fix provided by HighwayStar for screen flicker : Flicker when using the cursor seems to be removed by the parameter HWC_DISABLE_CURSOR_PLANE: = true
would it be possible to roll out a fix, is there a way to have smaller updates, instead of full IMG.
There are currently 2040 users online. 1 members and 2039 guests.
