Rom: Android Pie for S912
ReaperMan thank you for your reply.. I installed the rom to m8s pro l.. Everthing is good only wifi and Bluetooth can not turn on... I used cable for internet. I don't know about for my wifi chip... I try another firmware.. Will post the result...?Last edited by ekytjhin; 05 August 2020, 09:35.
Originally posted by hungphutho View Post
Please test my version aml_upgrade_package_s912-pie-ddr792-3G-1000-H96ProPlus-beta3.img fix only 2G memory , fix keeps randomly freezing and restarting
tested the rom, incredible fast,also fast booting, only one so far, maybe my fake ram, using it on GTI ULT, DDR4, 3/32gb, AP6255, everything works, wifi, 1000lan, remote, root included, did not use Magisk, but only BT does not work, can you include an OTA update Zip for AP6255, like you did on my other GTIUlt with QCA9377, please reply and thanks.
Originally posted by RiCkLaR_atvX View Post
Originally posted by ppromo47 View PostHis ROMS are 32 Bit based on DavietPDA's release, did you notice any major difference?
Edit: Watched several of Vasily's videos, can't remember if it was this ROM, but one the ATV roms had the Status Bar and Navigation Bar activated which you don't normally have in a standard-ATV build.
Guest
Originally posted by RiCkLaR_atvX View Post... can't remember if it was this ROM, but one the ATV roms had the Status Bar and Navigation Bar activated which you don't normally have in a standard-ATV build.
Olá senhores, instalei na minha Box está versão, update_khadas_pie_multiwifi_20200711_arm64_LPDDR_1 00Mbit_ATV.img, através do amlogic burn, deu certo 100% sucesso, mas ao conectar na TV não liga mais, oBo PC não reconhece mais, já tentei por cartão SD também não deu certo. Por gentileza como unbrick está Box?
Modelo: TAP PRO
Tipo: Caixa de TV
Sistema: Android 6.0
Processor: Amlogic S912
CPU: ARM Cortex-A53
Core: 2,0 GHz,Octa Core
GPU: ARM Mali-T820MP3
RAM: 2G
RAM Type: DDR3
Desde já agradeço.
Originally posted by Sousasilva View PostPor gentileza como unbrick está Box?
Modelo: TAP PRO
Tipo: Caixa de TV
CPU: ARM Cortex-A53
RAM: 2G
RAM Type: DDR3
Desde já agradeço.
Download the ROM this morning, haven't tried it yet, time permitting plan to give it a run this weekend.
Since I dont have account I cannot download, ana when I try to create account there is image verifiation which I cannot pass as i dont know russain.
Search the "MaskROM" forum thread and see if anybody else has shown the exact location for you to short-the-pins(if reset button not working) to recover your box with PC+Amolgic_USB_Burning_Tool. Next time read the .IMG file name correctly, LPDDR is not same as DDR like your board has.
Do you have account with 4pda.ru, can you share the file, please.
Do you have account with 4pda.ru, can you share the file, please : https://4pda.ru/forum/dl/post/204727...ouse_3.4.0.zip
HighwayStar bumerc May i request you to look into the repo : https://github.com/anpaza/linux_vfd
Would you have time to integrate this into the kernel and release a flash-able kernel patch, its a humble request.
Thank you.
There are currently 2103 users online. 1 members and 2102 guests.
