Rom: Android Pie for S912
    XVortex
    Features:
    Based on ATV9 beta3 firmware by hungphutho/DaivietPda
    All peripherals, mouse in IR remote control
    LED - works
    Optimized partitions to increase free space
    Some of the settings may not work
    Android TV 9
    Port hungphutho/DaivietPda ATV. v5.2:
    tx9s_atv_vtx_v5.2.7z
    https://yadi.sk/d/mqvZgrS9n1HApg
    ATV shell and software suite.
    "Imprisoned" under the control of the remote control.
    Not Working:
    Playback settings
    chromecast
    TWRP
    Android AOSP 9 Pie
    Port hungphutho/DaivietPda (AOSP). v5.2:
    tx9s_aosp_vtx_v5.2.7z
    The default shell is SquareHome3. It is convenient to work even without an air mouse.
    TWRP not working
    Playback settings
    Chromecast
    "Installed via UBT / SD-Card (bootloader cannot be erased)
    The firmware is as lightweight as possible."
      Originally posted by ReaperMan View Post
      XVortex
      Features:
      LED - works
      Android TV 9
      Not Working:
      Playback settings
      chromecast
      TWRP
      Android AOSP 9 Pie
      TWRP not working
      Playback settings
      Chromecast
      can you post some screenshots please? when you say LED working, is it the front clock?
        Take a peek at referred website. You will need google translate if you don't speak Russian.
        I think they are discussing red/blue light
          Ok I thought you had installed it, I was asking because I saw vorkex had notification bar, but when I extracted the systemUI into this ROM, notification is not enabled.
          EDIT ; System UI is 32bit hence doesnt work on 64 bit
          I have Tx92 which has front clock led
          There is one patch for Vontar X3, which I guess also has front clock and people have reported it working.
          https://4pda.ru/forum/index.php?show...ost&p=96551405
          I tried to flash this but failed, I guess the kernel is secured and INSMOD command fails.
            Shame it didn't work. If you figure it out, post again. I'm sure others will benefit from your sharing.
              SlimBox V.6.1 Mod
              XVortex Dev:
              AOSP and ATV
              Tweaker Beware :*** Have not found yet more info as to features or how to install***
                SlimBox V.6....
                You missed the topic, that falls under S905X2/X3 firmwares.
                  Probably, tired!!
                  As a TWRP back-up of Slimbox, laid atop of v.5.2.7, would it wreak havok?...yeah...definitively...sorry
                  I'll delete post and try opening my eyes...hmm
                    It wont work with patching, drivers needs to be integrated in the kernel, unfortunately I have no experience in linux or kernel development
                      Originally posted by Massimo1993 View Post
                      bumerc tested but still same problem, it freezes and then it will reboot. I think there are no easy way to fix this, too bad.
                      Thanks again for helping.
                      Please test my version aml_upgrade_package_s912-pie-ddr792-3G-1000-H96ProPlus-beta3.img fix only 2G memory , fix keeps randomly freezing and restarting
                        Made a port based on
                        Android TV 9. v5.2 XVortex
                        and a
                        port based on
                        Android 9 Pie (AOSP) v5.2 XVortex
                        for:
                        Device:
                        Z69 Plus
                        (LPddr3 3/64 AP6255)
                        (2 usb ports, Lan1000, WiFi, Bluetooth, remote (Mecool))
                        Sewn working TWRP
                        Link
                        https://yadi.sk/d/QfzxWhacoQsuXQ
                        ~ Maikl ~
                        for the hint to configure playback!
                        Thanks to the author:
                        XVortex
                          Thanks for your work! hungphutho
                          I have two Sunvell T95Z Plus ddr3 3/32 (AP6255)
                          I have the firmeware (aml_upgrade_package_s912-pie-beta2.img) LAN1000.
                          Flash and with success.
                          Rom is going really well!
                          USB 2.0 x 2 = work
                          WiFi = work
                          Bluetooth = work
                          Remote = work
                          Led = work
                          S/PDIF = work
                          MicroSD = work
                          Front display = does not working!
                          LAN1000 = does not working!
                          help me pls...
                          Thank you
                            Tested it on my H96Pro+ (DDR4), below function works great so far...
                            Lan
                            Bluetooth
                            Remote
                            4K video: 1080p to 1440p (tested from Youtube)
                            2 x USB port
                            Great build! Thanks so much!
                            BTW, will you make a AOSP version with TWRP in the future (e.g SlimBox V.6.1 AOSP Mod)?
                              Thank you for your hard work... I installed img from daiviet aml_upgrade_package_s912-pie-beta2-lpddr3-3G-wifi9377-100.img but my wifi can not turn on. My mac show 02:00:00:00:00:00. Can someone help me please? Thank you in advance.
                                Is your WiFi chip actually a 9377?
                                Maybe, ap6255, ap6330
                                Is your network cable unplugged.(just in case..)
                                You may need another firmware to get WIFI.
