Rom: Android Pie for S912
Good find! These build just a 'proof of concept' to show that S912 rom could be built from same sources that used for newer socs with no modifications in framework, hals or kernel. I wonder why vendors dropped S912 boxes support while it still supported by amlogic. so I just downloaded Khadas sources for android 9.0 for their newer devices and built it with generic gxm_q201_v1 config for u-boot and dts.
Modifications was only necessary to make ARM64 build, since there are no devices with ARM64 builds avaliable expect ODROID devices. I have applied neccessary patches to khadas sources so ARM64 build can be done for any generic amlogic soc device.
Originally posted by bumerc View Postthat's very good, which device did you test, 2g or 3g?
I have Tx92 3/32 LP RAM.
I managed to get the TWRP workingdo you know if Magisk will work? and GAPPS 64 bit?
EDIT :- Recovery goes back stock after reboot
- Magisk work, i was able to install.
- I was able to flash GAPPS 64 bit Android 9, but I lost launcher, using google assistant i was able to launch play store and install alternate launcher
- Link to TWRP
Originally posted by HighwayStar View PostGood find! These build just a 'proof of concept' to show that S912 rom could be built from same sources that used for newer socs with no modifications in framework, hals or kernel. I wonder why vendors dropped S912 boxes support while it still supported by amlogic. so I just downloaded Khadas sources for android 9.0 for their newer devices and built it with generic gxm_q201_v1 config for u-boot and dts.
The "support" is was there but, it had some severe issues with screencomposer, and both sdk's had the same issue.
Now, who fixed the issue? you think it was Amlogic? no it was khadas who fixed it by themselves because of their VIM2 device. (ye at the time i even talked with a amlogic engineer and he said... forget it)
Anyway money talks as you all know....
ho and btw... 10 also as the files in there... but some bad surprises coming for the rom editor devs.
hmm there are really something wrong with my account... i can see you post if i logout but i login i do not see it... wt*.....
Hardkernel's odroid hwcomposer works fine too on S912....
Who cares anyway, what cares is that looks like some guys going to have some life back on their s912.Last edited by superceleron; 10 July 2020, 14:23.
Originally posted by ReaperMan View PostVIM2_Pie_V200624
Attention - for LPDDR3 2g(untested)/3g devices
Tested on H96pro+ 3g,
* Install via sdc_burn
>>download<<
S912 Corelec https://androidfilehost.com/?fid=4349826312261740571, aml_upgrade_package_s912-pie-beta2.img
in test at this moment if it is stable I hit the linck
DDR3 / DDR4:update_khadas_pie_multiwifi_20200707_arm64_ATV.img
[/QUOTE]
@larrywilson
Would it work for beelink GTI ult ddr4 , 3/32gb? Thanks
There are currently 2031 users online. 1 members and 2030 guests.
