Rom: Android Pie for S912
    Originally posted by ReaperMan View Post
    secureos?
    What is?
    I guess that means I don't need it?...LOL!
    Does it affect root???
    P.S. 16 releases, you rock on the overkill!
    Well secureOS is for L1 devices only, used on non L1 devices = widevine L3, non secureOS used in a L1 box = that box becomes L3. (hope you guys understand it now)
    And i decided not to do 16 builds, to many builds and do not have time for it.
    So 4 builds max, 2 userdebug and 2 user builds(user builds are for ppl that need non root and selinux enforced for ISP Tv Apps).
    And i will post one flashable zip with 100mbits eth fix.
    And i also post the LPDDR3 uboot to the ones that have that type of boxes, they just needs to edit the img and change them.
    And that is it, then let this chip die in peace.
    I won't be doing secureOS since their no use for it anyway, the L1 keys used on this devices are to old now and not meet parameters for Android9, so the keys wont work ok anyway.
      will any of these roms work on minix u9h if so which one is it and has anyone tried it
      thanks in advance
        @superceleron,
        Thanks for the info. You put in so much time and effort!
          thanks in advance
          yes they will work, i tested in mine but you will lose the usb ports and L1, in the minix they used a different way from "stock" amlogic on how the usb ports are "powered on".
            superceleron sorry to bother again but there is any hope to get a rom/patch with the u-boot for h96 pro+ from bumerc?
              Also im not supporting any particular remotes, other than the 2.4g g10 and g10s and some other 2.4g remotes... on IR ones.. well i do not care!
              So no remote control the u9?
                well CEC works... if you do not need the usb ports.
                  Posted : https://forum.freaktab.com/forum/tv-...fi-bcmbt-qcabt
                  I will post tomorrow the "Normal" build.
                    I'm sure everyone is eager...to also buy you a beer for your efforts.
                      Originally posted by bumerc View Post
                      I compiled the u-boot for v3 board some time ago, try this
                      u-boot_ddr4-cl16_v3_board.tar.xz
                      I've tried to unpack and repack the image from daviedpda with your uboot but every time i try to flash, this error will appear
                      [0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
                      Do you have any suggestion on how to resolve this?
                        That means that cant find a compatible DDR.
                          I need uart log for the timing update, bl2 blob may also have to be replaced..
                            No problem, think i can do it but what do you mean by bl2 blob has to be replaced?
                            edit: is this good enough? I did took it with superceleron 7.1 rom installed
                            Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
                              https://pastebin.com/v0a7hA4t
                              I said maybe. I don't see any DDR4 memory in the log, although the high CL value indicates DDR4 memory and this is strange, wait for the next update..
                                I don't really know what a bl2 blob is, that's why i've asked.
                                Thanks for spending time on this, thanks a lot.
                                I will try to install a stock build and check if something changes. Meanwhile here there are the photos of all the ram chip (i think)
ID:	810739Click image for larger version
ID:	810740Click image for larger version
