Rom: Android Pie for S912
ATV9 for BB2:
Edit link: https://drive.google.com/file/d/1jv9...ew?usp=sharing
Wifi, bluetooth work
Vendor remote part work. Can not work in mouse mod and inscrese/descrese volumeLast edited by bigthinks; 26 October 2020, 11:22.
Hello Guy`s,
I am struggling a bit and need some guidance please.
My box is a h96 pro + 3 G ram 32 Memory ......I have the Blue PCB version board with the LPDDR3 S32-V6 and wifi 9377
I installed this image to the H96 Pro box and it seems to works flawless.WiFi, Bluetooth, original remote etc all seem to function Great!.
I am really unsure of one or two things..... so any help here Guy`s would be most helpful.
Do I now install any OTA Update image onto of the image? I suspect I don`t as the post with the images on from the link do not show any OTA update file on it`s section LPDDR3. S912 DEVICES USE RAM LPDDR3
For reference the image I used.: aml_upgrade_package_s912-pie-beta2-lpddr3-3G-wifi9377-1000.img 9377 lan 1000Mbps (h96 pro + tx9pro 3G
From this post : https://daivietpda.com/2020/07/rom-a...-amlogic-s912/
One final thing please........How do I go about doing a TWRP Backup ?
I want to do it via TWRP and save the image to SD CARD For future reference once I have it tweaked the way I want.. What is the compatible TWRP to use and or Boot from SD Card ?
I did try one or two version , But was never able to boot into TWRP with them ,So I suspect I need the correct procedure or TWRP files etc to achieve this.
Thank you Guy`s for your help.........PS: also if you Guy`s have any recommendations concerning any tweaks I can do? with this would be most welcome.
Edit Update... After Numerous days and hours of trying to get TRWP to work with this image....Unfortunately I must call time on a fix.
I literally tried every TWRP .zip (maybe 20 to 30) and a shed load of recovery.img files without success. I got close to making a backup on 2 of the TWRP files I tried... Only for is to fall at the latter ends with errors ... can`t really recall the exact errors , but one was to do with no keys registered or something similar and the other was an error pertaining to a 255 error..... I then went digging again to find more info.......But I soon began to realize that trying to get TWRP to work on the said image Really truly had opened a can of worms. I will just have to live with No backup option on this image and hope for the best.
Best Regards,Last edited by polosolo; 25 October 2020, 18:08.
Originally posted by theghost1951 View PostEasy way first is to make sure you have root with Superuser.... then from playstore install Flashify then use it to flash twrp.img file....done
Every TWRP . recovery file I tried to flash....... using TWRP App to install to flash the recovery file to the OS did indeed install ...But never worked when trying to boot to recovery using the toothpick reset option or booting to recovery via the powermenu-1.6 ...resulting in a none starter blank screen on TV
I really tried literally everything I could think of and even went as far as extracting recovery.img from the latest Slimbox 9 pie builds which have working TWRP
Now I may have just missed something..........But Honestly don`t think I did....as I tried nearly every conceivable option I could think of...But I am sure there is a solution..
I did test out the Latest Slimbox android 9 images and both installed and where working OK on the box....Only problem is they are full of bloatware and it would take an eternity to get them back to a vanilla state.
The image from Davidpda is as close to vanilla as you would want and it`s Super fast......everything just works except getting TWRP to work.
Thank for your suggestion thou.
Best Regards
Originally posted by theghost1951 View PostInstall root check and supersu from the app store. One to check for root the other is the root interface. Total root and conformation is need before another step
Thank you again for your support.
Best Regards.
Slimbox v10
Port_SLIMBOX-ATV-TANIX-TX9S-v10_to_Z69 + (LPDDR3) Mod
https://mega.nz/file/AZpAGQQA#NisTW6txtz8ntZjqkGnwtLYu5f1V0SqK8WcO1-mI2so (update 2020-27-10... SU Fix)
Dev: lyubodelev
"Only flash via UBT at your own risk!
Device: Z69 Plus (LPddr3 3/64 AP6255)
1. Bluetooth does not work!
2. Root - only silent
Changes:
• Additional sound settings
• Dark theme by default
• Additional CEC settings
• Busybox updated to version 1.32.0
• Wi-Fi country code setting
• Wi-Fi simulation option
• Allowed to save to external drives
• Timer switch off set-top box with indication
• Disabled notification channel warning
• Added configs for Logitech keyboards
• Applied all patches of the Lucky Patchera system
• System amendments"
Previous Z69 Plus mods from lyubodelev have also worked on my H96 Pro+, wifi 9377
I'll try to post AOSP version if it becomes available.
* This is a mod of an initial release of Slimbox v10 (based on Tanix TX9S). Be informed how to "Unbrick" your China Box before proceeding.Last edited by ReaperMan; 27 October 2020, 23:09.
There are currently 4145 users online. 0 members and 4145 guests.
