Rom: Android Pie for S912
Display Clock for China Boxes
(Work in progress, will not work on all China Boxes)
linux_openvfd
Dev: Ico747
https://4pda.ru/forum/index.php?show...st&p=103249649
This repository contains the source code for the FD628 and similar LED display controllers, Controller datasheet.
The FD628 controller is often used in Android TV boxes with a 7 segment LED display at the front.
Although the FD628 controller has support for a multitude of different display configurations, the current implementation only supports common cathode and common anode displays with 7 segments. The driver can also support FD650, which uses a variation of the I2C communication protocol. In addition it supports HD44780 text based LCD displays, using an I2C backpack.
Install via TWRP
Sunwell_T95U_VFD.zip (560.68 KB)
https://www.udrop.com/4Gco/Sunwell_T95U_VFD.zip
Vorke + Z6 + VFD + x92conf.zip (560.75 KB By:Mike1099)
Vorke-Z6_VFD_T95Z-1_patch.zip (393.14 KB By:Alls)
https://www.udrop.com/8SnS/Vorke-Z6_...5Z-1_patch.zip
Sunwell T95Z (Second screen?)
https://www.udrop.com/4KKp/Vorke-Z6_...5Z-2_patch.zip
Vorke-Z6_VFD_tx92_patch.zip (393.14 KB By: Alls)
The init.d folder is now located differently than previous Slimbox firmware.
The clock patches can work for slim 10.2 and 10.3, if you move the script from the sdcard / init.d folder to system / etc / init.d and set it to proper rights.
For those who dare to experiment. (Be sure how to Unbrick your China Box)
Take configs from here https://github.com/arthur-liberman/vfd-configurations
Edit: 99_Openvfd
From the config you take vfd_gpio_clk = ??? vfd_gpio_dat = ??? vfd_gpio_stb = ??? vfd_chars = ??? vfd_dot_bits = ??? vfd_display_type = ????
Ex. insmod / sdcard / custom / openvfd .ko vfd_gpio_clk = 0.76.0 vfd_gpio_dat = 0.75.0 vfd_gpio_stb = 0.53.0 vfd_chars = 4.3.2,1.0 vfd_dot_bits = 0,1,2,3,4,5,6 vfd_display_type = '0x01,0x00,0x00,0x00'Last edited by ReaperMan; 16 January 2021, 17:40.
linux_openvfd
Dev: Ico747
Install via TWRP
Edit: 99_Openvfd
Originally posted by ReaperMan View PostNot an expert.
Take a look at this link:
"This repository contains configuration files for devices that have a 7 segment display (most often they're Android TV Boxes), driven by FD628 or a similar controller."
Development and porting of firmware for devices on SOC Amlogic
https://4pda.ru/forum/index.php?showtopic=998873
Vorke + Z6 + VFD + x92conf.zip (560.75 KB By:Mike1099) https://www.udrop.com/4Gcq/Vorke+Z6+VFD+x92conf.zip
thanks Reaper Man With this patch front remote on ir started working, LED still doesn't work
???????tx92 3 32 gb lpram
I have login problem currently for 4pda.Chrome.
This is the suggested patch
TX8 Max
Sbx_Viet_TX8max
Dev:syndrom42
Port sbx_mecool_bb2_and_pro_pie_v10_4
Replaced boot.PARTITION and bootloader.PARTITION, from Vietnamese firmware
(aml_upgrade_package_s912-pie-ddr792-3G-1000-H96ProPlus-Beta3-9377)
ATV
AOSP
https://drive.google.com/file/d/1_y1...ew?usp=sharing
Originally posted by ReaperMan View PostI have login problem currently for 4pda.Chrome.
https://4pda.ru/forum/dl/post/219128...tx92_patch.zip
There are currently 1980 users online. 0 members and 1980 guests.
