Rom: Android Pie for S912
Greetings friends! I annoy you with a query ... Is it necessary to be root so that the x plore manager does not deny me access to certain folders? I ask this because I am trying to certify my device with the method "/data/data/com.android.vending/shared_prefs" and then change to true in "finsky.xml" and I can't get to that point. I have installed Slimbox 10.5 aosp which by default is not rooted. You have the option to select root in the Slimbox configuration, but I'm afraid I won't be able to unroot it again .... I prefer not to be root, I like it better .... I hope you can excuse my bad english .... Thank you very much in advance !!!
@bark,
To access system folders, you could make a flashable package for recovery or TWRP. Instead, if you are not a programmer/dev, you must be rooted to access and copy/paste files.
Some programs(even if root not active) will see the root file structure and refuse to run.
Some testers have been successful replacing SU with Magisk and hiding root...others would have to help you in this regard.
Be sure how to "UnBrick" your China Box when testing!
Originally posted by ReaperMan View Post@minonano,
This TWRP is run from SD card..being temporary
You would need recovery.img for our chip, based on TWRP or somehow convert this to recovery(?). Last recovery.img available was v3.4.0 upped by lyubodelev.Last edited by minonano; 28 January 2021, 03:33.
Beelink GT1 Ultimate / Dealdig BOXD6Slimbox 10.5
(Update to 10.4.1 I did not succeed, so backup recommended)
Dev:Azur4
https://4pda.ru/forum/index.php?show...00#entry101860 284
beelink_slim_atv_10_5.7z
beelink_slim_aosp_10_5.7zbeelink_slim_atv_10_5_LP_AP6255.7z
LPDDR3 + AP6255
beelink_slim_aosp_10_5_LP_AP6255.7zlyubodelev
Patches for BlueTooth from
Patch_for_BT_AP6255.zip
Patch_for_BT_QC9377.zip
Originally posted by ReaperMan View PostTANIX-TX92
SLIMBOX_Port 10.5 not LPDDR
Dev:tehcno
SLIMBOX-TANIX-TX92-Qualcomm_QCA9377_1000-ver10.5
ATV:
AOSP:
https://yadi.sk/d/cDfj-IZugTlUnQ
There are currently 6867 users online. 0 members and 6867 guests.
