i want stable rom can know my wifi and bt and with twrp because tuner with openelec
Rom: Android Pie for S912
Full backup with TWRP was more successful under Android 7,did tuners work well under Android 7? The development of current iterations of Pie struggle with full TWRP.
The only way to be happy with a ROM is to flash and test for a while.
Search through this and other vorke forms.
Maybe sbx v8.xx, or Aidan's Android 9 ATV version made from Mi Box:
Home Screen With Apps ^^^NEW Home Screen, Update From Play Store ^^^ Preinstalled Apps Initial Set Up Screen Initial Set Up Screen 2 About New Google Dream X Included Google Play Protect Certified This is My Android 9.0 Firmware, This...
Check also Vasily Shevchuk's mods:
XVortex mods?
ReaperMan and friends.
Hello.
I have a GT1 ULTIMATE 3GB / 32GB WIFI AP6255.
I downloaded the sbx_beelink_gt1u_lp_ap6255_atv_v12.img firmware, but I can't apply it to my GT1 ULTIMATE.
GT1 ULTIMATE connects with USB_Burning_Tool_v2.2.3.3 but I can't apply firmware. It shows an error right at the beginning of the firmware installation.
Please:
1) Am I using the correct firmware?
2) Am I using the proper tool (USB_Burning_Tool_v2.2.3.3)?
3) Any additional tips?
Thank you very much.
Originally posted by webipsum View PostReaperMan and friends.
Hello.
Please:
Are you sure what Ram type your device has? That LP (sbx_beelink_gt1u_lp_ap6255_atv_v12.img) means Rom is only for LPddr, not for regular DDR type. Usually if you open the box the ram type will be printed on the board somewhere. Visually LPddr boards have one ram chip an one emmc, while DDR is 2 or 4 ram chips also with just one emmc, another visual identifier is that most LP boards are bright Blue or dark Blue.
RiCkLaR_atvX
The description reads:
RAM: RAM 3G
RAM Type: DDR4
ROM: ROM 32G
ROM Type: eMMC
Wifi is: AP6255
And the serial number starts with: AX12GSL...
I currently use the firmware: GT1_707N0_AP6255 (stock firmware).
So sbx_beelink_gt1u_lp_ap6255_atv_v12.img firmware is not suitable for my GT1 Ultimate, correct?
Best thing to do is search Google for Pics of your device and board, or go to Beelink's forum and see what owners of the AX12 serial number say.
V2.2.3.3 has worked for me, until v12(might be related? )If it is an error with USB burn tool, then try to downgrade...or install fresh from another computer, v2.1.7.3.
Otherwise, you might try to modify the firmware with a reliable bootloader from previous Android 7, discussed in early pages here.
Originally posted by ReaperMan View PostBeelink GT1 Ultimate / Dealdig BOXD6Slimbox 10.5
(Update to 10.4.1 I did not succeed, so backup recommended)
Dev:Azur4
https://4pda.ru/forum/index.php?show...00#entry101860 284
beelink_slim_atv_10_5.7z
beelink_slim_aosp_10_5.7zbeelink_slim_atv_10_5_LP_AP6255.7z
LPDDR3 + AP6255
beelink_slim_aosp_10_5_LP_AP6255.7zlyubodelev
Patches for BlueTooth from
Patch_for_BT_AP6255.zip
Patch_for_BT_QC9377.zip
can you help, TX92, 3G/32G LP RAM, BT:9377
I know others have Bluetooth /USB 2 port problems.
Try flashing again...it can help...sometimes.
You might have to wait to see if new patches will be made. The old patches may not have the proper rights or root location. Current root rights seem to be poorly implemented . I can't modify some system folders or add files.
ReaperMan
???????Thanks that would be great, I still like this version "BOX6D_update_khadas_pie_multiwifi_20200711_ar m64_ LPDDR3_ATV.img" but I just cannot root or TWRP it, because of USB issue.
After launching temp TWRP, there is no way to connect USBOTG and mouse at the same time
In the mean time can you download this dtb.img from 4pda, I dont have 4pda account since its russian.
Thank you in advance, you are a star!!
There are currently 2775 users online. 1 members and 2774 guests.
