Rom: Android Pie for S912
@gkohar,
Are you currently on Android 9?
There are about 7 versions of the PCB
Green board, blue board and black PCB board
How does the China Box run with factory firmware? (android 7?)
Does it reboot if you do not use it?
If it runs fine for a short while....
-Likely heat issue
-or failing power supply
-or corrupt memory chips
@marciobill,
Port_SLIMBOX ATV-x92-v14.7_to_ Z69 _Plus (LPDDR3) (ATV)
Get it before it is taken down
Dev:lyubodelev (4Pda)
- slimBOXtv version: 15
- Added additional Bluetooth settings with displaying the battery charge of the remote control
- Increased the display size of the logo and boot animation
- Added AOSP keyboard with default Holo Blue theme
- Corrections to the operation of image modes
- Added optimally tuned Nova Launcher mod, activated as master (PIE)
- Involved Google services with less memory and CPU usage
- Key remapping has been modified in the Button Manager and is launched from the settings
- System amendments
Download ATV or PIE
https://slimboxtv.ruLast edited by ReaperMan; 21 February 2022, 08:12.
-Likely heat issue
Strangely when I'm using Android 7.1.2 H96PROPLUS_mac_20170826.7z the reboot problem reappears
For the hardware I'm using the board is green, I've also modified a small fan to make it less hot
This is my pcb
Wisdom PCB manufacture
They only followed up with 2(?) firmwares.
Last official:
Android 7.1.2 H96PROPLUS_mac_201701120.7z
The Bootloader may have been made more stable?
Try this firmware? If stable, update to sbx v15, do not >Erase Boodloader< ?
Nice fan.. if it draws too much power (the power supplies are poor) = brownout and a reboot will happen.
I've used a powered USB hub in the past(experimented with batteries also)
https://mega.nz/file/9NxiVZiB#WgSZOT...XH6glnf6ZBseN4
Originally posted by gkohar View PostThanks for the advice, I'll give it a try. I'll let you know later
It's quite confusing for me.. Because sometimes it just reboots immediately, sometimes it takes up to 15 minutes to reboot and it also takes up to 1 hour not to reboot at all, you could say it's random
I seem to remember issues with Power Supply
Also read on old Threads 2amp output is not actually true 2 amps
Something like 1.4 amps....
Maybe try Adapter with 3 amp output
Happy testing
Last official:
I've tried flashing the wisdom rom, but it keeps rebooting randomly Finally I thought maybe it was due to a lack of power, so before I bought a new adapter I tried to parallel it with a power usb (power bank) and it worked my unit didn't reboot at all for 1 hour of use
Looks like I really have to buy a new adapter with more power
Thank you for all
This is my device
Originally posted by freddy View Post
I have this Box 3 / 32 collecting dust at the moment.
Happy testing
Yes, it seems your suggestion is correct. I've tried paralleling the power with usb (powerbank) and apparently the reboot problem doesn't occur
I was ill buy a new adapter
Reaper Man
Thanks for the advice..
Thank you for all
This is my device
slimBOXtv 15.1
Changes:
• Added support for Bromite SystemWebView (download from the project website)
• The AOSP keyboard startup icon is hidden
• Replaced Setup Wizard (ATV)
• Fixed issue with logging in to Google account
• Updated WebView and Google Play service
• Added additional Bluetooth settings with the display of the battery charge of the remote control
• Increased logo and boot animation size
• Added AOSP keyboard with Holo Blue theme by default
• Adjustments to the operation of image modes
• Added optimally configured Nova Launcher mod, activated as master (PIE)
• Google services with less memory and CPU usage are used
• Key reassignment has been modified in the Button Manager and is launched from the settings
• Systematic amendments- Added support for Bromite SystemWebView (you can download it from the project site)
- Hidden launcher icon for AOSP keyboard settings
- Replaced by Setup Wizard (ATV)
- Fixed issue with google account login
- Updated WebView and Google Play service
Clean installation is strongly recommended !!!
Download ATV or PIE
https://slimboxtv.ruLast edited by ReaperMan; 24 February 2022, 08:25.
Beelink GT1 Ultimate
For revision LPDDR3, Wi-FI -AP6255, SN: LPN1, SN: AGTA
It is possible that hardware (LPN1) is very similar...?
*** Always know how to UnBrick your China Box before tweaking/flashing. ***
There are currently 3718 users online. 1 members and 3717 guests.
