Rom: Android Pie for S912
    You could try DIY version....so much effort
    There is s912 development... so anything is possible.
    Android 12.1 (?)
      Hi All
      my device is kiii pro s912/3/16 (with damaged internal wifi/bt)
      my question:why i can add external usb wifi (Rtl)with Atvxperience 7.1.2 And coreelec 9xx
      But i can t added the same wifi usb with all version of slimbox
      why?
        Possibly the kernel used and/ or drivers not included.
        Contact the dev via telegram or 4pda to request help.
          ReaperMan Can you please tell me which slimboxTV rom version is compatible with my Alfawise H96 Pro+, 3/32 DDR4 green pcb?
            I sold my last H96 Pro+. Which was a green(?) board.
            I took the risk (3/32 Blue firmware) since I could Unbrick this box and flashed. It worked fine.
            In the past I would I would extract the bootloader from 2/16 and overwrite the same on 3/32 with Amlogic tools v6. There is a better decription a dozen pages back.
            *** Always know how to UnBrick your China Box before tweaking/flashing. ***
              I have a Beelink R68II which is roughtly the same board as GT1, with S912,DDR3, 2G+32GB,QCA9377
              I searched sliboxtv.ru,there's only GT1 Ultimate,either DDR4+QCA9377 or DDR3+AP6255.
              Where is the link for DDR3+QCA9377? or which rom is the best now for R68II or GT1? Currently on stock rom of GT1 android 7,some apps have problems.
              thanks.
                I do not have a Beelink R68II to test.
                Possibly Ugoos am3 versioon of slimbox may be compatible. You will have to research since it (your China Box?) is discontinued...
                If you read the begining pages of this forum, there is info on copying and inserting your bootloader files from Android 7 into Android 9 (Slimbox) firmware.
                  Plz if u can more explain (exemple)
                    Android 12.1 (?)
                    https://wiki.radxa.com/Zero/dev/Line...roid_TV_flavor
                    "Official" XDA 3ad: https://forum.xda-developers.com/t/o...vices.4313743/
                    Here's some -maybe- useful (re)sources for builders:
                    ...hope to see "generic" S912 builds soon !
                        slimBOXtv 15.4.1
                        Changes:
                        • Fixed non-work items in the settings
                        • Amendments to the activation of Ui Mode for applications
                        • Disabled influence of commands from LG remotes
                        Download ATV or AOSP
                        slimBOXtv
                        https://slimboxtv.ru​​​
                          slimBOXtv 15.4.1
                          Changes:
                          slimBOXtv
                          Hello Bro
                          I already tried slimrom 15.4.1, but ethernet/front LED doesn't work
                          wifi is working well
                          ​​​Could you please let me know what is version compatible with my tx9 pro 2gb/16gb box!
                          Click image for larger version  Name:	IMG_20221117_015246.jpg Views:	0 Size:	83.8 KB ID:	831062
                            Try seeking around these forums
                            (firrmwares)
                            Verify if you have DDR3 or DDR4 ... LP on Non LP memory.
                              missing rom for version AP6335 gt1 ultimate
                                A refresh look is coming soon:
                                Applies to: Android 9 & 11 versions.
                                (Other features TBA ?)
                                https://www.youtube.com/watch?v=yLWy...ature=youtu.be
