Rom: Android Pie for S912
    slimBOXtv 9.8.5 (Android 9) via patch
    Changes:
    • Fixed the work of the Autostart application in the settings
    • Fixed search in Advanced settings
    • Fixed setting bootanimation in interface settings
    • Added extended support for the installed font by other applications
    • Added choice of 55 fonts
    • Replaced hosts in ad blocker with a more simplified one ?
    Download patch
      slimBOXtv 9.9 (Android 9)
      Changes:
      • Added to the settings in the Internet management of Google services
      • In the interface settings, a change in the shape of the icons in the blind, application icons has been added
      • Replaced hosts in ad blocking with a more simplified one
      Download ATV or AOSP
      https://slimboxtv.ru
        slimBOXtv 9.9.1 (Android 9) via patch
        Changes:
        • Added NTP server selection to Date and Time settings (requires activated root access)
        Download patch​
          slimBOXtv 9.10 (Android 9)
          Changes:
          • Removed cinemas
          • Updated built-in applications
            Sir I have a H96 pro plus s912 that is a 3gb ram/ 64 gb rom, and in your site there is no such version compatible for mine (only 3/32)
            Could you please make a compatible one for my box ? because I tried both version 2/16 and 3/32 and failed both.
            Thanks​
              slimBOXtv 9.11.2 (Android 9) via patch
              (requires v9.11 be installed)
              Changes:
              • Corrected information in the About project setting
              • Added installation of your bootvideo, copy the video in MP4 format to the UpdateSBXtv folder
              • Added installation of your Bootanimation, copy bootanimation.zip to the UpdateSBXtv folder
              Download patch for ATV or AOSP slimBOXtv
              Прошивки, инструкции, приложения для Android TV Box
              slimboxtv.ru​
                slimBOXtv 9.12 (Android 9)
                Dev:Slim House
                Changes:
                • New logo and loading animation
                • Disabled search window in AOSP launcher
                • Russian language activated in LeanKeyKeyboardPro
                • An attempt to disable auto-renewal of applications in the market
                • System amendments
                slimboxtv.ru​​
                Always research how to Unbrick your China Box before proceeding!​​
                  hi all
                  plz if there any rom slimboxtv with two conditions (mecool kiii pro s912 and multiwifi) tell me
                  thx
                    Originally posted by HouceinM View Post
                    mecool kiii pro s912 (and multiwifi ???)
                      i try this one but is not multiwifi(my internal wifi is broken and i want use external usb wifi ralink mt7601 but i can t activat it)
                      if not compatible with this rom plz tell me a name of usb wifi supported ( i try 3 models of mediatek but i m fail)
                      mybe i know u Mr mAtvXk (i try Atvxperience it s very good but it s android 7 and your r member of this team,,,you can help me plz
                        ...name of usb wifi supported...
                        Only BCM and Mediatek are supported, check in vendor/etc/wifi and vendor/vendor/lib/modules...
                          Can you recommend a specific, tried-and-true type for me? i m trying 3 models of mediatek and fail
                            @HouceinM,
                            Tp-Link UE300
                            Rtl 8153 chip. UE300 ver 3.0 (there are 4 versions in total)
                            Members on Slim House's Telegram channel have suggested it works on some China Boxes.(depends on kernel build).
                              ReaperMan, is Slim house telegram channel only in russian? Any translation available and how? Thanks.
                                Originally posted by ReaperMan View Post
                                @HouceinM,
                                Tp-Link UE300
                                Thx for reply…i will try
