Rom: Android Pie for S912
    slimBOXtv 9.1 (Android 9, based on factory firmware, version 15 in the past)
    Changes:
    • Fixed pairing of Bluetooth devices
    • Changed interface settings
    • Fixed work Miracast
    • Updated and activated ViPER4AndroidFX
    • Added presets for ViPER4AndroidFX convolver
    • Added selection of bootvideo, color settings icons, logo
    • Increased the number of notification icons in the status bar to 10
    • Disabled from updates in the market Atv Remote Service and Google splash screen
    • Updated built-in applications
    • System amendments
    Download ATV or AOSP​
      Originally posted by ReaperMan View Post
      A refresh look is coming soon:
      Applies to: Android 9 & 11 versions.
      (Other features TBA ?)
      https://www.youtube.com/watch?v=yLWy...ature=youtu.be
      nice
        slimBOXtv 9.2 (Android 9, based on factory firmware, version 15 in the past)
        Changes:
        • Added to the settings Autostart application
        • Power indicator goes off in sleep (Vontar X3 and similar)
        • Minimum set of built-in programs (Copyright)
        • Added new bootvideo, logo, bootanimation
        • System amendments
        Firmware will be uploaded soon!​
        Прошивки, инструкции, приложения для Android TV Box
          slimBOXtv 9.3 (Android 9)
          Changes:
          • Amendments to the settings for choosing the type of recent
          • Replaced ViPER4Android with a better version
          • ViPER4Android built-in startup in settings
          • New logo and bootanimation in the style of Google TV
          • System amendments
            slimBOXtv 9.3 ATV​ for Beelink Gt1 (?? DDR-4 ??)
            Mod by:lyubodelev
            sbx_beelink_gt1u_qca9377_atv_9_3_cor
            GT1 has DDR3 memory - it means you do not flash LPDDR
            GT1 Ultimate can be either DDR4 (not LPDDR) or LPDDR3 (for LPDDR)
            (Do not test if you do not know how to UNBRICK)
              slimBOXtv 9.4 (Android 9)
              Changes:
              • Added Acceleration button (clear memory) in TVLauncher (ATV)
              • Keyboard LeanKeyKeyboardPro is used as the main
              • Device certification in Play Protect
              • Added a large wallpaper pack for your launchers
              • System amendments
                Thx
                  slimBOXtv 9.5 (Android 9)
                  Dev:Slim House
                  Changes:
                  • Added script for updating firmware with patches from internal memory from the UpdateSBXtv folder
                  • Fixed setting wallpaper for TVLauncher (ATV)
                  • Colored default settings icons
                  • System amendments
                    bumerc still active here? Could you reup your 64bit build again?.. kind regards
                      slimBOXtv 9.6 (Android 9)
                      Changes:
                      • Added option to install updates from settings
                      • Added Dolby ATMOS
                      • Added the ability to set a custom background for TVLauncher (ATV)
                      • Fixed disabling wallpaper in the settings for TVLauncher (ATV)
                        slimBOXtv 9.6.2 (Android 9) via update patch
                        Changes:
                        • Added to settings Download patch with updates
                        • Added to settings Ad blocking using hosts
                        • Added to settings Use Google DNS servers
                        • Added to settings Improve network speed
                        • Added to the settings Force wifi
                        • Amendments to the update installation mechanism
                        Download patch with updates​
                        Always research how to Unbrick your China Box before proceeding!​
                          slimBOXtv 9.6.3 (Android 9) via update patch
                          Changes:
                          • Amendments to setting the color theme of the interface
                          • Activation without rebooting colored settings icons and background for TVLauncher​
                            Only briefly tested slimBOXtv 9.6.3.
                            Seemed Cpu ran hotter 52° to​ 75°​ ..maybe a bit sluggish too. Cpu when idle/after several "cleaners" still indicted 22% usage.
                            Tested on friends Alfawise H96 Pro+ .​
                              Is there any announcment Slimbox will release Android Roms > Android 9?
                                These are Android 9 releases.
