Rom: Android Pie for S912
    slimBOXtv 9.6.4 (Android 9) via patch
    Changes:
    • Added to settings Download patch with updates
    • Added to settings Ad blocking using hosts
    • Added to settings Use Google DNS servers
    • Added to settings Improve network speed
    • Added to the settings Force wifi
    • Amendments to the update installation mechanism
    • Amendments to setting the color theme of the interface
    • Activation without rebooting colored settings icons and background for TVLauncher
    • Returned the installation of their backgrounds for TVLauncher without rebooting, copy your picture to the UpdateSBXtv folder on the internal memory (ATV)
    Download patch
      ReaperMan after the patch,9.6.3 or 9.6.4,Android wireless dispaly seems broken, 9.6 seems fine.iPhone mirror works in all versions.
      what's your experience?
        Briefly tested 9.6.3 & 9.6.4 on DDR3 China Box. Cpu cycles when idle still consumed 20% and obviously without fan, video played and glitched @ 75° C.
        Maybe because of DDR3 vs my other DDR3/4 LP on previous Sbx firmwares .. seemed sluggish.
        ( I can't true test WiFi , current location sux .)
        If v9.6 was fine...return to that firmware.
          slimBOXtv 9.7 (Android 9)
          Changes:
          • Replaced video to adjust the image to better
          • Added Convolver presets for ViPER4AndroidFX
          • Added to the settings Dynamic background for TVLauncher (ATV)
          • Increased selection of color themes up to 16
          • Returned the installation of their backgrounds for TVLauncher, copy your picture to the UpdateSBXtv folder on the internal memory (ATV)
          • Cleaning in TVLauncher replaced by rocket (ATV)
          • Fixed black screen on first system startup
          • System amendments
          Download ATV or AOSP
            slimBOXtv 9.8 (Android 9)
            Dev SlimHouse
            Changes:
            • Fixed red background in settings
            • Amendments to color themes
            • Added support for color themes for toast messages
            • Added support for color themes for Autostart applications
            • Changed font selection in interface settings
            • Updated busybox
              slimBOXtv 9.8.1 (Android 9) via patch
              Changes:
              • Fixed the work of the Autostart application in the settings
              Download patch​
                ReaperMan to download the patch do I have to use yandex? And if so how can I do it in English? Thanks
                  Try using a browser with Translator addon
                  Chrome Mozilla have add ons.
                  Then select always Translate to English
                  Great for slimBOXtv site
                  And 4pda
                  Happ Testing
                    I am currently not running this version of Sbx. Just as a test, check and try, somone mentioned that the patch was available via the >Update option in >Settings????
                      slimBOXtv 9.8.3 (Android 9) via patch
                      Changes:
                      • Fixed search in Advanced settings
                      • Fixed setting bootanimation in interface settings
                      Download patch
                      slimBOXtv 9.8.2 (Android 9) via patch
                      Changes:
                        Hello
                        i bricked my Beelink GT1 S912 S/N G912Blk and i need the original Stock Rom to unbrick, cant find it anywhere or links dont work, Beelink Site is not helpful.
                        please got a link for original stock (Burntool Image or SD Card)? Thnx
                          https://forum.bee-link.com/forum.php...read&tid=41907
                          http://t.cn/RsUMGrY
                          Note:  This blog post outlines upcoming changes to Google Currents for Workspace users. For information on the previous deprecation of Googl...
                            LAN ON En Android, puede obtenerlo desde Configuración-> Más configuraciones-> Acerca de-> menú Estado.
                            Dissertation Writing Service in Pakistan
                            Thesis Writing Services pakistan
                              slimBOXtv 9.8.4 (Android 9) via patch
                              Changes:
                              • Added extended support for the installed font by other applications
                              • Added choice of 55 fonts
                              Download patch
