Rom: Android Pie for S912
    delete
      Useful FAQ posted,
      > Fix loss of internet after sleep should be helpful.<
      https://slimboxtv.ru
        "slimBOXtv version 12.1
        Dev:SlimHouse
        Changes:
        • Working system AFR for TV boxes on Amlogic S912 processor
        • AFR_CALC for manual use of the automatic frame rate function
        • In the recents window: pressing the MENU button will close all applications, pressing the UP button will close the selected application
        • Customizable Menu Button in the Remote Control Buttons app
        • Fixed setting to disable volume control in applications
        • Notification channel alerts are disabled by default
        • Screen resolution adjustments
        • Corrections in volume control for hdmi cec
        • PIE version will use Redmi Note 7 Pro in google services
        • ATV version will use MECOOL KM9 PRO in google services
        • System amendments
        The firmware will be uploaded soon, follow the site! "
          Originally posted by ppromo47 View Post
          Yes, complete erase. I am now on SBX v12 X92 (LP RAM applied by me)
          Bluetooth and LED still not working.
          You mean TX92? I have that device and I ran Khadas on it AND bluetooth worked but I had audio issues...
          So I switched to DietvietPDA's version
          Which Slimbox u use for Tanix TX92 LPDDR?
            I tried X92, it has the same dtb img with led config, unfortunately led still doesn't works...
              @ppromo47,
              gxm_q201_3g
                Originally posted by ReaperMan View Post
                Thank you are a star!!
                By the way I was able to install TWRP using the team TWRP 3.4 provided by Slimbox, that is the only temp TWRP which can access external sdcard.
                I am back on Android 9 released by HighwayStar 64bit, unfortunately it doesn't have GPIO and led files for FD628, if I unpack the dtb img and trf the files manully to /sys/class/leds/ folder will it work
                or do I need more ....
                  Is there a way I can unpack dtb and kernel from slimbox ROM, his IMG has drivers and scripts to interact with front leds fd628
                  I am guessing that if I am able to unpack rom then I can use files from/sys/class/leds folder to HighwayStar s rom.
                  His original rom doesn't have support for fd628, I would like to try if it will work.
                  ?????with customisation tool, the kernel and recovery cannot be unpacked it throws some error, is there any other way to unpack2
                    Mmh ...take those from DIETVietPDA! But shows only BOOT all the time lol
                      His ROM is 32 Bit, as suggested by bumerc, it wont work.
                      Originally posted by bumerc View Post
                      This means that this module was compiled in a 32-bit kernel environment and cannot be loaded by a 64-bit kernel. The DTB contained in the ZIP update is also for 32-bit kernel architecture. In order for it to work, the kernel + module + DTB must be compiled together. These 3 components must be included in the update ZIP.
                      bumerc would you be able to compile the modules for 64bit? I tried to setup on linux, but I am a noob, cant even setup build env....
                      I would really appreciate that...
                        "slimBOXtv version 12.2
                        Dev:SlimHouse
                        Changes:
                        • Corrections to the dark theme
                        • Corrections in the work of spdif
                        • System optimization
                        • AOSP keyboard with voice search
                        • The city of Kiev in the choice of time zones
                        • Sharpness in advanced picture settings
                        • Updating built-in applications
                        • System amendments
                        The firmware uploaded, follow the site! "
                          slimBOXtv project 2021
                          ATV and PIE firmware for S912 processors have been updated!
                          V12.2 (Updated)
                          Changes:
                          • Sound corrections
                          Download Firmware
                            I try it with mecool kiii pro
                            it s stable and great rom,,,but
                            no power off
                            when i want to shutdown the device it make restart
                              Did you try? >Settings >Device Preferences >Power . Choose how you want the device to behave on power action.
                                Yes i try it,,,,but same problem
