Rom: Android Pie for S912
    Originally posted by ReaperMan View Post
    You did better than me, I tried twice to find the cumulative patch 11.2. .I only found full firmware link.
    Check under s905x on slimbox site
    its same for gtiult
    Also were you able to install the full rom11.2 on your GTi alt?
      Thanks for the heads-up, I did not want to setup my system again! Will have to wait the G-Drive bandwidth limit.
      I don't have GTi, Azur4 posted v11.1
        Beelink GT1 Ultimate
        Slimbox v11.2
        ATV and Pie version
        for DDR4 revision , Wi-FI - qca9377 , serial G912 *
        for revision LPDDR3 , Wi-FI - AP6255 , serial LPN1 *
          Beelink gtiult
          Tried ddr4 ser g912, works OK no BT, even with bt patch,
          back to azur4,, with cumulative 11.2
            Originally posted by minonano View Post
            Beelink gtiult
            Tried this modded build https://disk.yandex.ru/d/z9jXThHYxw7Gdw from 4pda.ru for h96pro+ ddr4 11.2 pie (not atv), everything works pefectly fine! If bt doesn't work then flash bt_patch via twrp.
              It's suggested to turn off all WiFi and Bluetooth before applying the patch.
                Thanks I will try it and let you know .
                Update, still no BT with wifi and bt off, back to Azur4 11.1 plus cummulative patch11.2, I think Azure4 modified slimbox for GTI. Thanks reaperman
                  I tried the modded build below from 4pda.ru for h96pro+ ddr4 11.2 pie (not atv), everything works pefectly fine! If bt doesn't work then flash bt_patch via twrp.
                    Anyone knows how to fix bluetooth latency sound on Vorke Z6?I use BB2 latest slimbox rom.I noticed all slimbox rom versions have this issue.There is about 1 second delay.
                        See below H96 pro plus DDR4 mod build from PIE Slimbox v 11.2. Everything works perfectly fine. If bt dosen't work then flash the bt_patch via twrp.
                          1. Bluetooth has a maximum distance of about 10m.
                          2. Turn off the household WiFi if it’s possible.( to test anyways)
                          3. Bluetooth 5.0, may have shorter latency times vs older versions.
                          4. Household appliances like microwave, cordless phones or other devices that operate near the same 2.4 GHz frequency will also interfere with the signal of Bluetooth when they are working.
                          There are different CODECs for Bluetooth audio, and most of these CODECs have some latency. Slimhouse removed AptX-HD(?) the CODEC..not sure what was returned or replaced.
                          Look for Apt-X LL, or AptX Low Latency CODEC, if your Bluetooth device supports the CODEC. (How to replace...I'm not sure).
                          Google(?) app to test latency of different devices.
                            Originally posted by zackiptv
                            hi
                            j ai un beelink gt1 ultimate build 708no je l ai flashé avec plusieur firmware de la cite slimbox mais apres flash sa s arrete sur le logo .
                            est ce que c est possible de mettre a jour ma box a un android plus elevé que 7.1.2
                            Oui celui-là marche bien
                              svp je suis un debutant
                              donc je dois rooter ma box c est ca
                              les liens que vous mavez donné sont suprimé
                              Et voilà
                              https://4pda.ru/pages/go/?u=https%3A...oU&e=101860284
                              ou
                                https://github.com/google/walt/releases
                                Thanks reaperman but i assume is rom's issue! This doesnt happen with stock rom though.So i hope for a root fix or something..
