Rom: Android Pie for S912
Originally posted by ReaperMan View PostI have login problem currently for 4pda.Chrome.
This is the suggested patch
Vorke-Z6_VFD_tx92_patch.zip
https://www.udrop.com/8Y5i/Vorke-Z6_VFD_tx92_patch.zip
- Check id script is in Init-d folder
- Make sure to enable scripts in: Device Preferences> Developer Options.
- Try running scripts.
Or try:
Dev:Brahner from 4pda
Start terminal, "to start manually, you need to load the module first.insmod path / openvfd.koCheck the running modules with the command:lsmodEverything is ok, run openvfdService "
Manual install may be better? V10.2 different than v10.4.
Do not use Slimbox update via system... does not work(?) properly.
Otherwise, I'll try to update when newer/fix made available.Last edited by ReaperMan; 18 January 2021, 10:43.
Hey man, I am right where you are. Trying to move to slimbox, and am wanting atv, but prefer the non atv, as you can partially setup standard android to run with lean back functionality. May drop an install of 10.2 as I have made my box back to square 1. Fresh install of 7. And yes I can vouch the only way to drop 9 is to fresh install 7.
I guess I can install vastly rom, and let you know what it's like. I guess i can live with sync issues, but I can use MxPlayer pro for that. Not to worried about some audio sync issues. I can adjust on my receiver. Though I thought you can adjust in the audio menu on the box.
Originally posted by ReaperMan View PostTX8 Max
Sbx_Viet_TX8max
Dev:syndrom42
Port sbx_mecool_bb2_and_pro_pie_v10_4
Replaced boot.PARTITION and bootloader.PARTITION, from Vietnamese firmware
(aml_upgrade_package_s912-pie-ddr792-3G-1000-H96ProPlus-Beta3-9377)
ATV
AOSP
https://drive.google.com/file/d/1_y1...ew?usp=sharing
Or try:
it's strange though that ir remote started but not the LED
Oh, I did not know about developer limits with publishing to the public. Just so happens my 3+ year old box died (bad volatage to the rom... I may repair it, but decided on another purchase. Moving on to a 2021 updated hardware Ugoos X3 Pro. I see a lot of development going on for the the newer boxes, but Ugoos seems to be the go to for base firmware developers tend to port. I guess i am getting lazy or is see better development with the mid priced boxes. Anywho, it was interesting and a bit aggravating with the S912.
Originally posted by ppromo47 View Post
I am trying this on 64bit android by HighwayStar , tried manually loading the module, I get error : failed to load openvfd.ko Exec format error
Originally posted by bumerc View Post
This means that this module was compiled in a 32-bit kernel environment and cannot be loaded by a 64-bit kernel. The DTB contained in the ZIP update is also for 32-bit kernel architecture. In order for it to work, the kernel + module + DTB must be compiled together. These 3 components must be included in the update ZIP.
I am lucky that my device still boots with 32bit patch.
Good evening everyone unfortunately no atv 9 firmeware was accepted by the monster box "Magicsee ferro + amlogic s912 octa core, 3g 32g android 7.1 tv box 2.4g / 5.8g wifi support ota update lan 1000m bt4.1 media player 4k" ' same problem is a pure 64-bit box and ddr4 I tried a firmware atv 7 64 bits but still did not give an image even the firmeware completed successfully
Replace SU with Magisk
https://forum.xda-developers.com/t/p.../post-84305527- Yes you can install Magisk through TWRP
- BEFORE you have to delete the root by always flashing in TWRP UPDATE-unSU-signed.zip
- flashing the image of magisk_patched_new.img by selecting the boot partition.
- This is version 20.3 of Magisk,
- after you must update it by downloading the ZIP version 20.4 from the Magisk Manager application or by downloading it HERE.
- And then flash the ZIP with TWRP.
Always learn how to unbrick your China Box before testing.
There are currently 4970 users online. 1 members and 4969 guests.
