I have ddr3. will these firmware be suitable for my set-top box? I won't get a brick ? does this firmware have a driver for my Wi Fi HS2734 ?
Rom: Android Pie for S912
soldiaz,- Switch HDMI ports.
- Try a new cable
- Is your power adapter good: 5v - 3amp (I was sold a China Box with 1.5 amp adapter, under-spec) . A 2.5 amp adapter is nominal, mindful of the quality.
Most (all?) firmwares are based on khadas or Davietpda kernel.
You will have to flash again...guaranteed! Fresh is better! Micro stutters or flickering would ruin the experience.
If you are desperate to not flash, try turning off noise reduction in the build.prop system file. There are several lines to change. There is also another system file to modify "NR" setting ...I forget which one
I'm using Slimbox v10.2 and it has been the best so far. H96Pro+ LPDDR3 3/32
***Slimbox v10.3 is based on Ugoos kernel(?) which I am tempted to test in the next week or so. ***
Andrey6666 ,
I did a quick search but did not find the immediate info/link.
If I'm not wrong() It is possible that you have the "Black" PCB board. With no support given after manufacture.
I can't tell you how many times I have "Bricked" a box while testing and tweaking!
If you need android Pie(9) you may have to modify with Amlogic tools.- Copy and store to SD card your WiFi drivers from current firmware -Android 7.
- Get version of Pie that seems suitable(newest).
- Get Amlogic Tools v6
- Upack your original firmware and copy and store your DTB and BOOTLOADER,DDR and UBOOT https://4pda.ru/forum/index.php?show...#entry80540305
- Repack Android 9 with original DTB bootloader etc.(4 files?) from your previous Android 7 firmware
- Get Amlogic USB Burn Tool and deselect "erase bootloader" checkbox.
- Flash your firmware and hope for the best.
AMlogic Tools v6.0.0.
https://forum.freaktab.com/forum/tv-...sion-available
If I find the proper firmware(or really close enough)...I'll post.
*** Does not look too promising *** https://4pda.ru/forum/index.php?show...903145&st=4600
Maybe the reference in the firmware section to: H96 Pro+ HS2734A (Android 7) can be used as your base before upgrading To Pie? But will "Pie" Kernel still have code for HS2734A ???
Originally posted by ReaperMan View Postsoldiaz,- Switch HDMI ports.
- Try a new cable
I flashed Davietpda beta2 9733 runs smooth, everything is working except for PiP ...I can live with that...BT and wifi working, Youtube no Green Screen! No flicker!
XDA Forums:
Sealowed said:
Yes you can install Magisk through TWRP by flashing the image of magisk_patched_new.img by selecting the boot partition.
BEFORE/(First?) you have to delete the root by always flashing in TWRP UPDATE-unSU-signed.zip
This is version 20.3 of Magisk, after you must update it by downloading the ZIP version 20.4 from the Magisk Manager application or by downloading it HERE.
And then flash the ZIP with TWRP
**A bit obscure from description. Give it a try if you are testing and report success?**
***Maybe you might need to patch the img for your China Box here: https://topjohnwu.github.io/Magisk/i...atching-images ***
@isovitisgr,
T95z Plus seems similar to TANIX TX9S
Dev:BlackVictor
https://4pda.ru/forum/index.php?show...ost&p=99336434
ATV
AOSP
Alpha version AOSP 9 (NOT STABLE!)
Slimbox 10.2
Dev SlimHouse
ATV or AOSP
*** Learn how to Unbrick you China Box before testing firmwares! ***
Coming soon?
Android 9
"SlimBOX version 10.4 ATV and PIE
Announcement of changes:
• Updated CastReceiver for video broadcasting
• Fixed bug with launchers
• Additional settings cleaned of rubbish
• ViPER4AndroidFX autoloading works
• Auto setting of impulses for ViPER4
• Miracast added
• Init.d scripts moved to internal memory
• Fixed disabling root access, now it is not seen by programs with su checking
• Added themes Blue, Gold, Green, Red, installation from the patch installer
• Replaced the system font with RobotoMOD2018Bld
• Modding the application for installing system updates
• Added setting wallpaper and slideshow to settings
• Updated built-in programs
• Updated google services"
There are currently 1825 users online. 0 members and 1825 guests.
