HI is asking for key code in mega, impossible to download
Rom: Android Pie for S912
Originally posted by ReaperMan View Post@kos25k,
Bug free?
The best way is to research which compatible firmware is needed. Then test for your China Box and what you want to accomplish from it. The slimbox pie versions have been very good (I'm on v10.2). Slimbox v10.3 mods are based on Ugoos(?) kernel which may provide an improved experience for some?
Originally posted by ReaperMan View Postkeep x88 and sell z6 (x88 also has a Slimbox mod)
or
keep z6 and sell x88 (prices/ new chips will arrive in another year?)
or
Christ-mas is almost here and some parent or relative would appreciate the gift of love...(and a shiny China Box)
Btw do we except any cheap processor greater from S922 soon?Also S922 is the greater till now?
Tell me what firmware ATV9 is suitable for M96X Plus processor S912, 8 memory modules, Wi-Fi module HS2734A. Lan 1000mbit. Flashed several times Wi-fi does not work, I can't find the firmware with working Wi-Fi. Need Android TV 9 firmware
Amlogic S912 Octa core ARM Cortex - A53 cpu up to 2 GHz
ARM Mali - T820MP3 GPU up to 750 MHz
FLASH 16 GB EMMC
SDRAM 2 GB DDR3
Originally posted by ReaperMan View PostFrom developer: SlimHouse.
https://4pda.ru/forum/index.php?showtopic=993324
Slimbox v10.3 (Tanix v10.2)
Tanix TX9S
https://yadi.sk/d/EIIUzh9sWJOh0g
Ugoos AM3
https://yadi.sk/d/R-SsRsI69nBU_A?w=1
MECOOL M8S PRO
https://yadi.sk/d/TStTMgVNzgCYVw?w=1
need support for the HS2734A Wi-Fi module. this is important to me.
ReaperMan : I flashed hertz_upgrade_package_pie_2_3g_qca9377_lpddr3 and experience FLICKER ISSUES. Is ther a way how to fix this? I dont want to flash again..
Or must I flash new? which one?
2020-07-11
Mod 3
DDR3 / DDR4- fixed flickering cursor issue
- Removed code that overwrite recovery when installing custom recovery
- added support for 1/2/3 gb of memory for use on other consoles with the same hardware
LPDDR3 3Gb only:
100 Mbit LAN: update_khadas_pie_multiwifi_20200711_arm64_LPDDR_1 00Mbit_ATV.img
1Gbit LANBOX6D_update_khadas_pie_multiwifi_20200711_arm64_L PDDR3_ATV.img
There are currently 1650 users online. 0 members and 1650 guests.
