Rom: Android Pie for S912
Originally posted by bumerc View Post
Before giving error it stayed longer at 2% compared to the first build you made.
I did install the SHMOD firmware that has stock bootloader for ddr4 v3 version of h96 pro+
here is the log https://pastebin.com/Rn6GRnPL
hope this could help.
Thanks again for your help and time, i really appreciate.
the same error as the first one and the error it gave me was instant at 2%, no loading.
Maybe the timing on u-boot@ddr4_timing_update_v3_board.tar.xz was right and that's why it did halt for few seconds at 2% before failing for another unknown reason.
I did use the amlogic tools 4.0 to extract and rebuild the image.
EDIT: i tried again the last 792mhz version with celereon instead of daviedpda firmware but this time was strange it gave me an error few times and then it started to flash but it stopped at around 70-80% with
Code:[21:39:29 594][HUB2-1][Err]--failed:Verify Failed with sha1sum, origin sum "824ccc63ea00322766feee53434a10571d2a1ef7" != gen sum "6edf912a08f97b4cfcecbeb8a9f0acd6d4f49180" [21:39:29 597][HUB2-1][Err]--[0x30405004]UBOOT/Partition system/Verify patition/Error result
Originally posted by bumerc View PostThe timing is OK, it has not worked better since the last bl2 update. Did you replace all 4 files?
Code:RENAME u-boot.bin bootloader.PARTITION RENAME u-boot.bin.sd.bin aml_sdc_burn.UBOOT RENAME u-boot.bin.usb.tpl UBOOT.USB RENAME u-boot.bin.usb.bl2 DDR.USB
Originally posted by bumerc View Postedit: Wait, the 792mhz version works, you just have sha1sum errors, repack the IMG again
bumerc tried again with supercelereon firmware and except a small error at 2% it flashed and booted with apparently no problem, i've used an older version to repack it.
I will need to resolve the input problem and then i will test it to check if there will be any freeze/reboot.
Again, thanks a lot you did an amazing job.
Originally posted by ppromo47 View PostIs there a way to get bottom navigation and status bar enabled?
Also access settings in full screen, like in phone.
I can provide access to the PC for RAM 32GB cpu 2670 VirtualBox AnyDesk TeamViewer
Massimo1993
Very little information and no log. Are full 3GB RAM recognized? Install CoreElec on the SDcard and test it
sergej_a_g
Port of Android 9 ATV By SLIMBOX ver 5.1 ATV & AOSP
Wi-Fi, bluetooth,
remote control (does not include the console)
Lan 1000
Nav Bars,
root, script support.
Doesn't work: Playback settings, screen size.
Checked on MECOOL BB2 PRO 3/16.
ATV
Port_Android_9_ATV_32_Slimbox_to_BB2Pro_3_16_1000_ by_sergej_a_g.7z
~ Maikl ~ Update? LPDDR3_Port_Android_9_ATV_32.img
AOSP
Port_Android_9_AOSP_32_Slimbox_to_BB2Pro_3_16_1000 _ by_sergej_a_g.7z 1.17G
~ Maikl ~ Update? LPDDR3_Port_Android_9_AOSP_32.img 1.18G
https://yadi.sk/d/DHba_nZckwJjPQ
Tested AOSP on H96 Pro+ LPDDR3
AOSP and ATV launchers
Wi-Fi 2.4g
Bluetooth(?),
Lan 1000(?)
Nav Bars,
root/unroot, Initd script support.
Viper4android FX(?)
Screensaver
Titanium Backup write to external HD
No Google Play.
Doesn't work:
Playback settings(?)
Screen size(?)
Wifi 5g
Wifi has shutdown-once(reboot required)
File Transfer rate...max 4.5 MB/s
Still testing...seems nice so far.
Slow internal to SD file transfer!!!! 600KB - 2400KBs
Attaching USB HD not always seen.
Wake from screen saver may infrequently result in fuzzy text. Choose screen resolution again to restore.
Setting up AdGuard HTTPS, require screen lock pin code does not work.
P.S. Tried Customization Tool rebuild For Sc-Pie(error 7%) reloaded this AOSP and successful flash.Last edited by ReaperMan; 27 July 2020, 10:16.
There are currently 1876 users online. 0 members and 1876 guests.
