Minix Neo X7 - Finless 1.6 ROM - with overclock and frame skipping fix!
R: Minix Neo X7 - Finless 1.6 ROM - with overclock and frame skipping fix!
Ok guys,
Tomorow i'm gonna flash again kernel 1800/600/720, because last time when i did i had shutdowns and reboots. I've used an measy rc11 remote.
Now, tomorow i'm gonna use a simply mouse, to see if shutdowns and reboots was from the remote.
If not i'm gonna change the power supply too.....with an 5v 3.5A. (I have an mk808 too and when i flash oc kernels the power wasn't enough).
They are any other things that i can do? In order to make my new x7 work properly?
I read here that everyone is enjoying the 1800/600/720 kernel, without any problem.
I hope this work for me too...
If you guys have any sugestions....
Inviato dal mio GT-I9000 con Tapatalk 2
Also i HDMI 1.4 can be a issue, Minix A2 airmouse does not work propely when i use X7 with HDMI 1.4 but works perfect when i use it with HDMI 1.3.
Originally posted by Trhuster View PostAlso i HDMI 1.4 can be a issue, Minix A2 airmouse does not work propely when i use X7 with HDMI 1.4 but works perfect when i use it with HDMI 1.3....
https://en.wikipedia.org/wiki/HDMI#Version_1.3 boy do they differ, 1.4 can tunnel ethernet? i'm fascinated.
Originally posted by Catadarius View PostTrhuster, i saw that you had some problem with those kernels....can you tell me what was your final choice. I want to flash 1800/600/720.
Hello,
can this rom be installed trough CWM Recovery? I'm unable to install the drivers, but managet to get CWM installed to my device.
I tried with these instructions:http://androidtvnews.com/want-to-fla...-cwm-recovery/
.. but when opening the .zip in the CWM, it just gives error like "cannot install zip(bad)".
Or do you have any other tips regarding this topic:
(I can now boot to stock firmware and got it rooted + CWM installed.)
I flash the 1800/600/720 kernel, but i had shutdowns and reboots. Tried with an wired usb mouse and even with stock remote.
Then i change the power suply with 5V5a and still nothing...reboots and shutdowns.
Then i tried the other kernels with same results
The one who remains stable is stock kernel with vsync
Any ideas? It seems an hardware problem to me.
You can't fix everyone!
Re: Minix Neo X7 - Finless 1.6 ROM - with overclock and frame skipping fix!
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 3496 users online. 0 members and 3496 guests.
