Minix Neo X7 - Finless 1.6 ROM - with overclock and frame skipping fix!
    Re: Minix Neo X7 - Finless 1.6 ROM - with overclock and frame skipping fix!
    Originally posted by Jbardi View Post
    Unless the app is explicit when developed, you should be able to move it over to the sdcard after install. Another option would be to use a different parameters file when flashing the rom so you have more storage for apps and less for media. Changing the internal storage location from NAND to sdcard is probably the worst option to your dilemma.
    Try to download real racing 3 or asphalt 8, first one will place 10 mb on the app storage and 1gb of data on the SD card, while the second has 10 mb on the app storage and 1.5 gb of data on the SD card. that's why I need the space
    Sent from my GT-S7562 using Tapatalk 4
    FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
    https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
    My Plexi MK802IV mod
    http://www.freaktab.com/showthread.p...xi-MK802IV-mod
      Well what is your storage ratio between app storage and sdcard? Did you use one of the different parameter files on the rom install? You only mentioned 2.5gb between those 2 apps on the internal sdcard so I I'm still trying to figure out what is taking up all your space. Most android tv users have the actual stick devices with 4 to 8 gb storage, but you are running a Minix X7, so just trying to figure out what else you got going on that you would need to map your internal storage to a physical sd card.
        +100!!!!
        I am surprised he ran out of APP space to be honest.
        Something is not right with either his ROM flash or something has eaten a BUNCH of APP space.
        I mean the X7 out of the box has more APP space than any stock TV ROM out there!
        Makes no sense to be honest.
          Well, I finally moved this box to the family room and put it into general use. The 1.6 rom is stable and nearly perfect... in my opinion.
          But (always with the BUT) the audio is pretty thin... and I do mean thin... only on the Yamaha in the family room, the audio leaves something to be desired. When I switch XBMC to "HDMI" for audio, it makes this awful noise, so I have to quickly turn that off... my wife thought I was going to break her HTPC setup. So I have it set to "Analogue". Whatever that means, it is still on the HDMI, since that is all I have connected to the Yamaha.
          Is the optical working? I haven't hooked it up yet, because I thought it wasn't. Any ideas? I have to get better sound out of this somehow. Stereo is okay... that is what we use mostly anyhow. But it sounds weak and thin right now... I guess washed out is a good adjective.
          Any ideas?
            Any ideas?
            hello,
            wich kernel are you using with the finless rom ?!
            thanks a lot
              Originally posted by Trhuster View Post
              Regarding my early tests i did in the beginnig when i had many shutdowns and i did not know why. I now know that my T2 Airmouse make X7 shutdown randomly. And atm i use Kernel: 720P 1800CPU 600GPU 720DDR and it is stable for me. I did try 800DDR but it was to high for my X7 and it was not stable.
              Could you please explain the Airmouse issue? Because in these days I'm struggling with random shutdowns even when i tried a full 1080P movie (Avatar), some serious 3D gaming and some emulation without a single issue on 1800CPU/600GPU/800DDR.
              If I remember correctly all my tests were made without the Airmouse (I was stuck with poor range / performance, solved by a brilliant comment by phjanderson). Now that i solved my Airmouse range issues I have random shutdowns, maybe we have the same problem.
              P.S. More and more I dig in this rom and more awesome it gets. Every single problem I had was hardware related, not a single software problem. Two thumbs us guys!
                I simply started to test diffrent airmouses that i have. And with T2 X7 shutdown many times each day for a reason i don´t know. It works perfect with MK808. My Minix A2 does not work as it should either, it simply stops working randomly and i must unplug usb dongle and plug it back in to get it working.
                Rii 25 works without issues with X7 and so do Logitec K400. I suggest you try 720DDR instead of 800DDR.
                  Thanks, i will try to swap my Airmouse with my Wireless Desktop.
                  In these days i tried:
                  kernel_phja_1080_vsfsam_cpu1800h_gpu600_ddr800
                  kernel_phja_1080_vsfsam_cpu1800h_gpu600_ddr667
                  kernel_phja_1080_vsfsam_cpu1704h_gpu600_ddr720
                  kernel_phja_1080_vsfsam_cpu1704h_gpu600_ddr667
                  kernel_phja_1080_vsfsam_cpu1608h_gpu600_ddr667
                  Every kernel sooner or later showed some random shutdown, but ONLY when my Airmouse was connected. I'm going to try without it and I'm quite sure I'll be keeping kernel_phja_1080_vsfsam_cpu1800h_gpu600_ddr720.
                    Excuse my ignorance, but could this rom work with another device, say a CX919, with correct kernel?
                    Any drawbacks?
                    Signature? Signature!
                      Originally posted by shosh View Post
                      hello,
                      thanks a lot
                      I know this thread is getting long... from an earlier message of mine:
                      Okay, I have kernel_phja_1080_vsfsam_cpu1704h_gpu600_ddr720 flashed with the large icons boot (no airpin) and everything is looking good. I used Titanium backup to restore my apps and that went well (my 1st time to try that).
                      Antutu = 19259, passed the stability test with very small variations in temp, stayed cool to the touch (about the same as always).
                      I am in the process of reloading XBMC, apparantly some stuff didn't get completely restored by Titanium, but I need the practice... hehehe...
                      Overall, I am very happy. Fast, stable, no crashes. Brilliant work guys!!
                        Any ideas?
                        Have you tried the Viper4Android app from XDA? I use it and its the best audio enhancer/equalizer I've used. Really helps.
                        Sent from my Firefly V65 using Tapatalk 4
                          +100!!!!
                          Bob i redownloaded the rom and reflashed the device and now storage is working ok.
                          thx
                            Hi there ,
                            Can you please tell me how to use this app ?and wich sound can i enhance throuth this app , hdmi ?
                            Sent from my HTC One X+ using Tapatalk 2
                              [QUOTE=shosh;100596]Hi there ,
                              Sent from my HTC One X+ using Tapatalk 2[/QUOT
                              You download the app from here http://forum.xda-developers.com/show....php?t=2191223
                              It is like an equalizer app with various settings. You can enhance the audio, bass, loudness etc. I use it on all my Android devices.
                              Sent from my Faea HY509S using Tapatalk 4
                                when I flashed 1.6 I used default options. If I wanted to try kernel_phja_720_vsfsam, could I just use a thumb drive and recovery or would it be best to use the flash tool?
