Minix Neo X7 - Finless 1.6 ROM - with overclock and frame skipping fix!
    Originally posted by wizball View Post
    I know Elfa has a couple of them, this one for example.
    Thx, i found one at work from elfa 5V 7.5A. Anyone know if it is + or - in the middle of the pin?
      Originally posted by mahonypm View Post
      Pls try overclocked kernel. I had random reboots with stock kernel with any firmware. Now it's gone. I had screen freezes too using my Mele F10 pro. Some users reported that happens with minix air mouse. I realized that after some post that could be the problem.
      At the moment my system has been working since Friday.
      No creases, freezes at all.
      Kernel 1080p 1800 600 gpu 720 ram
      Wysłane z mojego Nexus 4 przy użyciu Tapatalk 4
      Will do, thanks for the advice
        Re: Minix Neo X7 - Finless 1.6 ROM - with overclock and frame skipping fix!
        I use the 720 kernel cpu 1800 ddr 720 is runs very good 2 days no crash or reboot . playing just fine.
        Verstuurd van mijn GT-I9300 met Tapatalk
          I Also have flashed this kernel and it is stable as hell.
          Is OC bad for yor device?
          thanks
            thanks
            Dont know maybe if it runs at 1800 constantly it is..
            Verstuurd van mijn HTC One met Tapatalk
              Start test with a solid power brick 5V 7.5A now with no overclock kernel. And if somone wonder + is in the middle pin (center).
              Edit:It was not power brick, shutdown after 10 minutes.
                How to flash the kernel?
                Hi guy !
                To flash the kernel we just copy the image file to root of X7 then rename to update.img...am I right man?
                Tks to confirm me back to burn my X7 now...
                  The + is the middle pin...checked already man.
                  The original adapter is only 3A...your one is so okay
                    Originally posted by dunghnguyen View Post
                    Hi guy !
                    No, use finless flash tool and uncheck all boxes except kernel. Click on the box at the right of kernel name and browse to kernel you want to use and then click flash rom.
                      I got it ...tks
                        I cant say for sure yet, but i changed T2 airmouse and plugged in K400 keyboard instead and so far stable. I did not think T2 airmouse could affect box to be unstable when not even using it, but mabey it is a fluke that box still going strong with K400.
                          hello friends. can you tell me pleasehow i can reflash to the stock kernel and firmware? thanks
                            just download the newest version of minix's stock rom (005) and flash it!
                            to download it you can go to: http://minixforums.com/
                            hope this helped.
                            "Success is a lousy teacher. It seduces smart people into thinking they can't lose."
                            - Bill gates
                              hope this helped.
                              thanks for the help when i will instal the stock rom it will erase and the boot.img and the kernel from finles rom 1.6?
                                Originally posted by stavster View Post
                                Great work. Can you confirm if the libmedia passthrough patch for xbmc is still in this build. I notice its not in the modification list compared to 1.5a
                                Regards,
                                It's not in this rom as it would not work. The patch needs to be updated for the 005 kernel which is what all pj's are based off if (for now ).
