Minix Neo X7 - Finless 1.6 ROM - with overclock and frame skipping fix!
    Originally posted by Trhuster View Post
    This short testing only with hobbitclip is amazing news for me. I used kernel_phja_720_vsfsam_cpu1704h_gpu600_ddr720 and this is first time Archos video Player and setting 60Hz did it as good as MX Player! So for me this is better than previos custom kernels from Phjanderson i used so far.
    And totally stomp on stock 005 imo. Will test some more tv apps Netflix ect tomorrow.
    Ok how is it compared to strauzo's SDK2 Nexus rom?
    Sent from my iPad using Tapatalk - now Free
      With this little testing hard to be sure. But with Archos and hobbit clip this is better for sure.
        Ok i use XBMC for video playback from my Serviio server. And use NFL game pass app to watch NFL games live and they run almost perfect on my telly still some small Shudders now and then.
          It seems like a great rom (I could say the best, but I haven tried it yet) hope that when my x7 comes everythig will work perfect. thx for your great work
          btw, you guys surprised me I thought It would take more days for this rom to be released
          "Success is a lousy teacher. It seduces smart people into thinking they can't lose."
          - Bill gates
            First stable 1080p ROM I've used.
            kernel_phja_1080_vsfsam_cpu1704h_gpu600_ddr720 about 20000 Antutu.
            I use K-R42 with letest Levy Hybrid ROM. (Perfect 1080p playback).
            Now I have NEO X7 also. I tried every 1080p kernel with Finless 1.5a, Lewy, Stock with 1080p kernel.
            Antutu ok. Stress test ok. Random reeboots.
            This one is first stable for me. Any reason why?
              Re: Minix Neo X7 - Finless 1.6 ROM - with overclock and frame skipping fix!
              Been testing for hours now.
              Looks like we got a winner guys.
              All is well..., no crashes or reboots.
              Verstuurd van mijn HTC One met Tapatalk
                It is alot better i can tell you. I used kernel_phja_720_vsfsam_cpu1800h_gpu600_ddr800 but i got i reboot when watching video almost instant. Will try a lower oc one now.
                Update:
                Added some additional kernels with all combinations between CPU 1608/1704/1800 and DDR 667/720/800: (optional download!)
                ROM -> Minix Neo X7 - Android 4.2.2 - Finless 1.6 ROM additional kernels (75 megs)
                Trhuster: can you try both cpu1704_ddr800 and cpu1800_ddr720 to see if cpu or ddr is the bottleneck for you?
                Want to thank me for my work? Donate to one of the administrators of this forum here or here, thanks!
                  Originally posted by phjanderson View Post
                  Update:
                  Yes i will do it. I watched 3 episodes californiacation late night and wife missed me going to bed becuase that is how exited i was! Archos is about 98% perfect for me and this is first time i am happy watching video with archos since i got the X7. It still have som glitch now and then using 60 Hz för 23.976 mkv video but we talk very MINOR things here now.
                  Fast test on Netflix is also promising but not perfect but i blame Netflix for that, will test more later.
                  Also for stablity no reboots or frezze all night.
                    Ok sorry to say I had my first crash and reboot. When watching madagascar 1920 x 1080p . in mx player .
                    Was changing the audio from english to dutch.
                    I am using the 720 kernel cpu 1800 ddr 800. Now I do the same and it plays fine.
                    Should I downgrade to less overclock?
                    On stock kernel i didnt had crashes will playing video ever....
                    Best regards
                      Best regards
                      Yes, can you try both cpu1704_ddr800 and cpu1800_ddr720 to see if cpu or ddr is the bottleneck for you?
                      This is the first time I pushed a kernel up to 800mhz ram, there's not much margin left there.
                        What's the correct voltage setting for:
                        Code:
                        CONFIG_RK_DDR_800=y
                        CONFIG_RK_DDR_800_VOLT=????
                        I'd like to test this on my T428 (your additional kernel package didn't include the config files).
                        NVidia Shield TV 2015 16 GB || Stock
                        NVidia Shield TV 2017 16 GB || Stock
                        Buy me a beer?
                          So i start to test kernel_phja_720_vsfsam_cpu1704h_gpu600_ddr800 because imo it is much harder to oc ddr than cpu in past oc tests i done over years with pc.
                          So far Antutu 20181 which is slightly less than with ddr720 suggest mabey ddr is to high. Anyway i start same video in archos as last time it rebooted and see how it goes.
                          Sidnote, i used A2 airmouse when it rebooted first time and it is some kind off bug when used with X7 (ironic). It just stops working some times and most often after it goes down in sleep mode. Only way to get it working is to reboot X7 and it is same in stock 005.
                          However A2 works perfekt with MK808 (ironic again).
                          But mabey it also casues instablity for X7, i don't use it in these tests no more.
                          EDIT: Played video for 30 minutes and no problem.
                            Code:
                            CONFIG_RK_DDR_800=y
                            667 = 1200
                            720 = 1200
                            800 = 1250
                            I will try to add these to marvin in my github repo soon.
                              So i start to test kernel_phja_720_vsfsam_cpu1800h_gpu600_ddr720.
                              Antutu 20951 which is lowest score so far.
                              Vill edit video test results after 30 minutes.
                              Edit: Video after 10 minutes shut down box, no reboot. So i guess my cpu is not very good or need more power, using stock power brick.
                              Edit2: Happend again.
                                The stock PSU of the X7 is very good, at least the EU plug one I got. The voltage was over 5v and under load dropped to just around 5v. A big contrast to the stock PSU of the T428 which easily drops to 4.5v and lower.
                                Just try some different combinations, or even the non-overclocked vsfsam version. I'm currently running that one as I do not need the extra cpu power on 720p.
