v1.1 Features:
Full Root with SuperSU
Debloat
Google Play Store fixes, to all for more compatible apps
Reduced System.img file size with ext4 file system
2, 4, 6 or 8gb user app space parameter files
Your choice of stock recovery or CWM (Stock Recovery is the default)
Multi-user support (I finally got this to work correctly) You will see a new option called Users in settings.
Some Internet/Wifi tweaks to improve speed and streaming
Some video performance adjustments
A few general performance enhancements
The Petrus Reboot app
Disabled OTA updates
Brand new boot animation from Tattman65
tun.ko, cifs.ko and m4.ko installed
Download:
RileyROM v1.1
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
