Sorry...it's fixed.
Pipo M6 Pro RileyROM 1.1
OOPS!!!!!
Sorry...it's fixed.Randy
3G module
Thank you for your work!
Maybe you know, Is there any way to disable 3G module correctly and alow Tablet to go into Deep Sleep?
I have Pipo m6 pro 3G with RileyROM 1.1.
And even if in: Settings->More..->Mobile networks->[Modem power] is off, it actually is On and discharge the battery. If I press On and Off manually, it is Off actually
Maybe, some script in cron or smth else.. or some how, temporally, fully disable 3g if possible..
[ATTACH=CONFIG]3416[/ATTACH] [ATTACH=CONFIG]3417[/ATTACH]
I noticed exactly the same behaviour, in fact in stby during the night the battery draw can be even more than 10%, i assume it could be due to the 3G module that doesn't go off. With both the stock and the rileyrom l've noticed that.if you appreciate my efforts this is the link for any donation:
If you don't actually use the 3g module, you might experiment using the wifi firmware.Randy
Originally posted by rrileypm View PostIf you don't actually use the 3g module, you might experiment using the wifi firmware.if you appreciate my efforts this is the link for any donation:
That's correct. But for the purpose of testing battery consumption, it is possible to flash the wifi version and see if it solves the problem.
We might find a solution in build.prop to disable the 3g modem temporarily...then enable it again when 3g is needed. I'll look into that...I think I've seen it somewhere.Randy
Originally posted by rrileypm View PostThat's correct. But for the purpose of testing battery consumption, it is possible to flash the wifi version and see if it solves the problem.
thank youif you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostThis sounds a lot better!
thank you
I had to remove google user account, clean cashe and after reboot enter account credentials again.
I am not sure if it will not repeat.
I have had similar problem with play store immediately after flashing, but now everything seems working properly.if you appreciate my efforts this is the link for any donation:
There is (in Wakelock detector) some event(module) ril-rk29-dataonly which also evokes the processor and it is possible that as irrelevant.
There is also runnig rild service, but I didn't find how to stop service in busybox =) (kill didn't help)
Ok, I'll try RileyROM 1.2 WiFi version for my Pipo m6 pro 3G in the soon and report you in that thread.
Feel free to ask any extra information
I think we should tell about this behaviour directly to PIPO customer care, they probably can test it and provide a bug fix, then wait for a modified firmware by Randy...if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostI think we should tell about this behaviour directly to PIPO customer care, they probably can test it and provide a bug fix, then wait for a modified firmware by Randy...
Besides, same issue in 1.2 Wifi version (installed on m6 pro 3g).
Could you write to customers?Or, maybe we shold write one big message?
Or do they have something simmilar to bugtracker? I know a lot of people with same issue on another forum...
Pipo has a forum, but it is in Chinese. I've joined and made a few posts before:
Google translate is your friend!!!!!!!!!Randy
There are currently 3244 users online. 0 members and 3244 guests.
