[ROM] Mecool M8S Pro LB Stock & Nano Nexus ROM (Android 7.1)
Trying to install this version now.
It installs fine. Reboots .... I get to setup screen where it asks to backup from phone or setup as new device (i tried both - same result). It says setup quit working (restart or mute something). Keeps doing that.
Any help would be appreciated. Thanks!
I confirmed last 2 letters in serial number were LB.
Guest
Okay, I'll take another run at the M8S Pro LB now that the S905X2 boxes are done. There's a new OEM firmware release (20181018.101400.V0213) to integrate anyway.
UPDATE:
Managed to flash stock 20181018.101400.V0213 onto my M8S Pro LB via SD card. Installed perfectly.
Non voice remote works .. no Wifi. Internet works via ethernet.
Hey, it's a start!Last edited by JohnnySmith; 09 January 2019, 22:52.
Hi
I installed this rom to my box
Everything is ok except that sometimes box frezes at the start up..
i have to disconnect the box from the power adapter until it boots again...it is a random error
Any idea?
thanks
There are currently 2235 users online. 0 members and 2235 guests.
