HPH NT-V6 RK3288 Custom Nougat ROM
    HPH NT-V6 RK3288 Custom Nougat ROM v1.0 19-12-2018
    Fixed ir remote
    Fixed OTG USB Port
    Fix resolution saved after reboot
    Fix Home button
    Add support for Amazon Prime Video
    Add support for bottom navigation bar and status bar
    Added Widevine L3 support
    Ad block by default
    NTFS write support
    BTRFS file system support
    Updated video codecs
    Display - Color mode support (Change if black levels are too low or too high, depends on tv support)
    Add lots of remotes support
    Launcher has weather support
    Fix Google Play Store, some apps couldn't install
    After Google Play Store updates, block updates for Youtube to have ad-free Youtube playback
    Virtual Xposed support
    Removed root so streaming apps can work
    Add Kodi 18 auto frame-rate support
    Improve browsing speed in apps
    Recent apps menu - Long press Home button - Press right to close a window with the ir remote.
    Go to Settings - About to Restart the device if needed, otherwise long press power button to shutdown or short press for sleep.
    Link: Here
    Pass: nagrace
    Do EraseFlash then Upgrade to flash
    Flash Tool(AndroidTool v2.59):Here
    (unzip with 7zip tool - http://www.7-zip.org/download.html)
    Fixed ir remote
    Fixed OTG USB Port
    Fix Home button
    Ad block by default
    NTFS write support
    After Google Play Store updates, block updates for Youtube to have add-free Youtube playback
    Removed root so streaming apps can work.
    Link: Here
    Pass: nagrace
    Flash Tool(AndroidTool v2.52):Here
    Hi Mo123 ,
    nice to see , hope it works well on many RK3288 Boxes , wish i could get this one to .imgc File ,
    so i could use & try it on my UT3 , shall load & try to flash the stock Way , would be nice if this
    Rom could be flashed , , to all enjoy the great Work of Dev. Mo123 ,
    greetings / gefattern
      I gonna download it this week...Thanks
      @mo123?what ver of Kodi are you using in your Rom?
      -Chromecast with Google TV
      - Android Q Android 10
        Kodi 18 20181217 arm I think.
        I just fixed auto frame-rate, so that now works in Kodi 18 too.
        But only 24, 25, 30, 50, 60hz.
        If you need to use 23.976 or 29.97hz, you will need a Kodi 18 from before April 2018 since they removed support for those rates to play at 24 or 30hz automatically.
        Will see if I can upload an old version.
        Only the Nvidia Shield and Rockchip RK3328(devices like MVR9) can play 23.976, 29.97 fractional rates correctly in Android as there are hardware changes needed for the HDMI chip so not sure why Kodi wanted to make video playback worse if so few devices support it.
        Will upload a new ROM soon.
          Updated flash tool in opening post, use AndroidTool v2.59
          Updated ROM v1.0a
          - Add Kodi 18 auto frame-rate support
          - Improve browsing speed in apps
          Kodi 18 auto frame-rate Guide
          1. 'Adjust display refresh rate' change it to 'On start / stop'
          2. 'Delay after change of refresh rate' change it to 2.0, 2.5 or 3.0 seconds for the best experience.
          If this setting is left on 0 seconds and you try to play a video, you will just get a spinning wheel and no video will start.
          3. Lastly, set up the whitelist resolutions with their frame-rates you plan to use.
          On a 4K tv, you can choose all the 4K frame-rates only or 4K and 1080p frame-rates, on a 1080p tv, you can choose all the 1080p and 720p frame-rates
          for the best experience. Try to leave DVD 720x480 resolutions out otherwise some old videos will look bad.
            Hi ,
            nice to see ,
              Hi, mo123. If I understand, the root access is broken in your firmware? is it possible to fix root?
              • mo123
                mo123 commented
                Editing a comment
                I havn't found a way to root 32-bit ROM's yet.
                Root only works on 64-bit like RK3328.
              Hi mo123.
              great work
              any chance of making it as image, so we can flash and run it from sdcard?
              i think my internal memory is somehow broken, as i get freezes with all roms every few seconds, but not when i boot from sdcard.
              i tried your rom and it's fast, but sadly also freezes for a second every few seconds.
                Originally posted by lonely2k5 View Post
                Hi mo123.
                great work
                Hi ,
                after download you must use 7zip to unzip , use Password , like Mo123 discribed , then
                you get a .img File this can be used for flashing with PC or for making a bootable SD ,
                hope it helps / greetings / gefattern
                  Hi, thanks for this firmware.
                  I have a Beelink R89, successful installation.
                    Hi ,
                    thanx for the info, but you can only make sdcard for updating. i want to boot and run the rom from sdcard.
                      Hi ,
                      dont think so the RK SD Upgrade Tool , as i remember good , has this option too ,
                      but not sure if it really works , but here on FT u can find Threads about that theme ,
                      good luck / gefattern
                        Is there a way to work the wifi with chip ap6330 ?
                        The rom is perfect Except no wifi .
                        My device is mk903v 2gb-8gb.
                        thank you.
                          You can use power of Magisk.
                          Just install magisk manager apk https://magiskmanager.com/downloading-magisk-manager
                          and flash my patched boot.img to boot partition https://mega.nz/#!Ack2GYDL!-Ip4_024d...Kzv6ovsX5o251M
                            Thank you, Dumonde!
