HPH NT-V6 RK3288 Custom Nougat ROM
Originally posted by el_easy View Post
Tell me how you flash this patched boot.img using Flash Tool AndroidTool v2.59 ? Thanks
yes flash it with AT2.59 , first Tab , only the "boot.img" , uncheck all others ,
then change on end of "boot" line to the patched "boot.img" stored on your Pc ,
good luck / gefattern
Hi Mo123
I try it(Nougat ROM) on my Cr12, and find out that it is not compatible
Flash successful but easy to crash--
Is there a remedy?
Originally posted by Dumonde View Post
You can use power of Magisk.
Just install magisk manager apk https://magiskmanager.com/downloading-magisk-manager
and flash my patched boot.img to boot partition https://mega.nz/#!Ack2GYDL!-Ip4_024d...Kzv6ovsX5o251M
Device Beelink R89
Guys, any body know what is the cause this error ''Match device type failed, stop running'' ? I am running stock Ugoos UT3S RK3288 NOUGAT BETA v4.0 that by the way is runnning fine, but i want something fresh and Im tryinh to install HPH NT-V6 RK3288 Custom Nougat ROM,but everytimes i press upgrade that error comes out..
Note:
I used differents AndroidTool versions, tried window 7 and 10..
Driver is properly installed since i used to flash Rom since Wasser Rom and nothingYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo-Chromecast with Google TV
- Android Q Android 10
Originally posted by el_easy View PostGuys, any body know what is the cause this error ''Match device type failed, stop running'' ? I am running stock Ugoos UT3S RK3288 NOUGAT BETA v4.0 that by the way is runnning fine, but i want something fresh and Im tryinh to install HPH NT-V6 RK3288 Custom Nougat ROM,but everytimes i press upgrade that error comes out..
Note:
look on your Flashtool , it is in ADB Mode , you need LoaderMode or MaskRomMode to flash ,
Device must be off , good luck / gefattern
Note:
You must also do an 'EraseFlash' then 'Upgrade', flash the update.img, not a boot.img
You could also try FactoryTool v1.60 if AndroidTool v2.59 doesn't work.
You must Enter Loader mode, insert a toothpick into the recovery hole then connect the USB cable to the OTG port and connect power.
really a new Factorytool Version , can you upload it , looks like the newest ???
and how they are all got into ADB Mode , maybe a solution to flash my bricked
UT3 ??? , if available ,
greetings / gefattern
Originally posted by gefattern View Postreally a new Factorytool Version , can you upload it , looks like the newest ???
Originally posted by Dumonde View PostAll rockchip tools here https://github.com/rockchip-linux/to...master/windows
first i want to say thanks for the Link , but so called FactoryTool 1.63 , from there ,
is in real the Version 1.50 , to see in Log , but for the rest some interesting Tools ,
maybe i can unbrick my UT3 with them , hopefully ,
There are currently 1840 users online. 2 members and 1838 guests.
